Thread: l26 Or L67 Rebuild
Results 1 to 12 of 12
GOTIT4CHEAP16 l26 Or L67 Rebuild 08-24-2011, 01:29 PM
Swiggles Re: l26 Or L67 Rebuild 08-24-2011, 03:59 PM
Reptile Re: l26 Or L67 Rebuild 08-24-2011, 11:15 PM
blueguy Re: l26 Or L67 Rebuild 08-24-2011, 11:16 PM
rynoman03 Re: l26 Or L67 Rebuild 08-24-2011, 11:34 PM
GOTIT4CHEAP16 Re: l26 Or L67 Rebuild 08-25-2011, 01:09 PM
GOTIT4CHEAP16 Re: l26 Or L67 Rebuild 09-03-2011, 06:59 PM
redlinepontiac Re: l26 Or L67 Rebuild 09-03-2011, 08:06 PM
t24moore Re: l26 Or L67 Rebuild 09-03-2011, 08:32 PM
GOTIT4CHEAP16 Re: l26 Or L67 Rebuild 09-03-2011, 08:56 PM
TheOtherNick Re: l26 Or L67 Rebuild 09-03-2011, 08:57 PM
GOTIT4CHEAP16 Re: l26 Or L67 Rebuild 09-03-2011, 09:13 PM
  1. #1 l26 Or L67 Rebuild
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    My friends l67 just went out and where trying to decide wheather to throw another l67 in there ($900 w/ 60k miles) or a super low mileage l26 ($570 w/ 60k miles).
    What would need to be taken off the old l67 and added to the l26?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: l26 Or L67 Rebuild
    Quincy, Mass
    youd basically would be doing a topswap to it. if the car has an aluminum subframe then you should be fine, otherwise swap the oil pan over or grind the subframe a little.
    No more GP 04 Impala SS Indy:
  3. #3 Re: l26 Or L67 Rebuild
    Bastard Reptile's Avatar
    Kansas City, MO
    I vote L67 personally.
  4. #4 Re: l26 Or L67 Rebuild
    **** L26's. And your crappy tiny rods.
    L67 all the way.
  5. #5 Re: l26 Or L67 Rebuild
    Topeka, KS
    L67
  6. #6 Re: l26 Or L67 Rebuild
    Bowie, MD
    Cool. Thanks for your suggestion guys. Where going L67 replacement.
  7. #7 Re: l26 Or L67 Rebuild
    Bowie, MD
    Update.
    So we found a cheaper l67 from a 99 buick riviera with 52k miles for $700. When we got there the lady ended up reducing the price to $600 for us because the supercharger was missing (which we didnt even need). The engine was also missing its Oil pan but we can just use the pan thats on the engine in his car. The engine is pretty dirty so we got alot of cleaning to do.
    Since its from a riviera, what needs to be swapped over to complete it? And any and all advice on how to clean the engine would be appreciated.
  8. #8 Re: l26 Or L67 Rebuild
    Waukesha, WI
    is the engine sitting on the pick up tube?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  9. #9 Re: l26 Or L67 Rebuild
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Ummmm has there been any real failures of L26 rods???? I dont think so. I would personally go with the newer motor. We have a mid 12 second gp running an L26 block as well as a turbo/xp running this block as well. Im running an L32 block with my setup below.
    From the looks of it the motor mount setup and the coil pack bracket should be the only thing that needs changing.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  10. #10 Re: l26 Or L67 Rebuild
    Bowie, MD
    No its laying on the rear stock manifold due to it not having an oil pan. Im gonna spend the labor day weekend at my buddies so i can finish helping him and we work on it together.
    @moree i hope that is all. We will be buying an engine stand, oil pan gasket, supercharger gasket, and Intake manifold gaskets sunday tommorow. Other than cleaning the engine, we should be done with everything by sunday evening or monday afternoon.
    Any suggestions on what to use to clean the entire engine and how to do it? Its pretty dirty. We might even paint it.
  11. #11 Re: l26 Or L67 Rebuild
    Charles City, IA
    engine brite gel and a hose once you get an oil pan on it and plug the intake.
    SMGPFC Two Nipple General
  12. #12 Re: l26 Or L67 Rebuild
    Bowie, MD
    Thank you nick.
  1. Top End Rebuild
    By MrPhotographer06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2011, 04:21 PM
  2. Think I should rebuild the m90?
    By neel2008 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 02:43 AM
  3. Done with my rebuild!!
    By Shang TI in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2011, 05:43 PM
  4. Another Rebuild
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2010, 04:11 AM
  5. to rebuild or not to rebuild
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 04:14 PM
