Thread: Taz's Offical Summer/Fall build list.
Page 2 of 17 FirstFirst 123412 ... LastLast
Results 21 to 40 of 322
  1. #1 Re: Taz's Offical Summer/Fall build list.
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Quote Originally Posted by Poil336 View Post
    still doing the ssm90 setup? i believe i have an extra balancer laying around somewhere. the spot for the standoff is easy to find too, and the other pulley hangs off the coil pack bracket.
    not sure I keep going back and forth, I'm trying to foucusing on getting all the big parts ready first and then figure out the other stuff
    I got the tb done and smoothed up the supercharger inlet alittle bit I'm not really sure what all to do to the inlet.
    On the outlet I got all the cutting done unless you guys think I should open the triangle up some more. I still need to sand/clean up the corners and where the numbers used to be alittle bit I'm not 100% sure how to go about doing that but I'll find away.
    I've pretty much completly given up on the idea of polishing everything on the outside, I still want to make it look nice so I'm either going to do a good job painting it myself or get it powder coated.
    I'm thinking of just doing everything ontop (s/c,tb) a similar grey to what the snout is from the factory, then the LIM and outside of the heads in red and maybe the fueal rails in red too even tho they are polished...
  2. #2 Re: Taz's Offical Summer/Fall build list.
    Troy OH
    paint the blower red, it'll match what you've done under the hood. primer and a cheap rattle can job made mine look alright. and silver fuel rails
  3. #3 Re: Taz's Offical Summer/Fall build list.
    Tazmania...
    You do know that I should have all the parts you need (idler/hb) sitting on the shelf or about to go into the trash pile, right?
    The list looks good, except. I'd suggest against buying Garleak gaskets. A couple rolls of gasket paper and making your own is much less expensive and works better in the long run. Add a tube of Permatex 26B gasket goop and you'll have the seal of champions.
    Beyond the mods in this thread
    http://www.grandprixforums.net/how-mod-lim-46931.html
    I'd consider adding JB Weld where the manifold gets thin
  4. #4 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    is the point in adding some jb weld to create a bigger gasket surface?
  5. #5 Re: Taz's Offical Summer/Fall build list.
    Yes. You can have 1/4" or you can have 1.5" of gasket sealing area.
  6. #6 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    I'm going to do that. I bet that sucker seals the first time everytime like that
  7. #7 Re: Taz's Offical Summer/Fall build list.
    If you follow what I suggested, you should seal.
    I've done 5-10 of them that way and buddies have followed the same. To date, not one leaked. And each one took a prybar to remove.
  8. #8 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    Today among many other things I completly finished the throttle body, its done and wraped up for safe keeping until the time comes. Heres some pictures.
    I know I still got along way to go but it feels nice to finally be putting something back together.
  9. #9 Re: Taz's Offical Summer/Fall build list.
    Because Wet Leaves Hippo Machine's Avatar
    Jun 2011
    Detroit, MI
    ^^^ looks good
    iLoveSpade
  10. #10 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    so I'm bumming because while inspecting everything before putting the supercharger back together I looked at the rotor pack again and I'm going to have to replace it in the near future. Its absolutly wasted I would bet money that after a month of being on my car both rotors will be completly bare...
  11. #11 Re: Taz's Offical Summer/Fall build list.
    So buy one cheap. Intrigue98 has one sitting at my place waiting to get sold. Contact him via pm for details.
    Where's your TB screen?
  12. #12 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    in a plastic bag on my desk lol
  13. #13 Re: Taz's Offical Summer/Fall build list.
    Glad to hear it.
  14. #14 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    man this is just adding up and up lol for $1200 the ssm90 kit is a steal if you ask me because every time I feel like I only got a few more things left to get It ends up being like $800 lol
    at this point I still need
    Injectors
    coil bracket
    balancer
    misc bolts
    Intercooler bolts
    valve springs
    valve retainers
    valve seals
    "Possibly new valves?"
    Headers
    Heat exchanger
    spark plugs
    oil and filter
    supercharger oil
    belt
    3.4 pulley
    head gaskets
    supercharger/Intercooler gasket
    throttle body gasket
    and the probablly another $200 to do braided fuel lines and briaded or sleeved lines for the intercooler and engine radiator
    Oh plus what ever I spend to have paul tune it...
    If I don't pick up some hours Idk if I can get this done by kcgp11
  15. #15 Re: Taz's Offical Summer/Fall build list.
    Let me know..You know what I got
  16. #16 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    Pmed
    So today I got more stuff back together. Yay!
    I have to redo the snout even tho I knew better I thought if I just put a light coat on it I could get away without stripping it to bare metal... yeah it turned out awful but after that I can finally work on the heads and then thats it rebuild wise which makes me super excited but it also sucks because I'll be sitting around waiting for enough money to buy alll the other stuff lol
  17. #17 Re: Taz's Offical Summer/Fall build list.
    London Ont, Canada
    paint looks good.. is the TB painted too? looks light, but its probably lighting.
  18. #18 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    I think it might be the other way around. The primer I used is a dark grey and I know I sprayed the blower lighter than I did the tb so I think thats why theres a shade difference I saw it when I put it together but I figured once theres a bunch of hoses and a filter around it will hardly be noticable
  19. #19 Re: Taz's Offical Summer/Fall build list.
    London Ont, Canada
    all the same or GTFO lol
  20. #20 Re: Taz's Offical Summer/Fall build list.
    Dec 2010
    Ohio
    close enough this isn't a show stopper anyways lol
  1. Offical DRL (Day Time Running Lights) Thread
    By Thunderturd in forum Visual/Body Modifications
    Last Post: 04-26-2014, 11:24 AM
  2. need someone to double check the build list
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2011, 09:13 AM
  3. Help me build my Xmas list of parts lol
    By jteske88 in forum The Rant Forum
    Last Post: 07-16-2011, 10:49 AM
  4. First Offical MAGMA Meet and Greet
    By Biohazed in forum Shows and Events
    Last Post: 04-12-2011, 11:09 PM
  5. Does anyone actually fall for this?
    By ROTTMAN in forum The Rant Forum
    Last Post: 04-09-2009, 01:24 AM
