Thread: P0171 Code--Check Fuel Pump
Results 1 to 3 of 3
  1. #1 P0171 Code--Check Fuel Pump
    PCMO
    I had been getting the P0171 code sporadically over the last couple years. In the last few months it was more common but still not consistent. The MAF sensor had been replaced. I was also having problems starting every once in a while and finally after getting the car started and running weak it stalled, also got a misfire code. I noticed that I did not hear the fuel pump when I turned the ignition on so I banged on the tank and it kicked on?!? So after getting a premium pump on ebay $45 shipped I have not had the code since. One thing I would recommend is to get the fuel pump o-ring before you start. The old one will not be reusable as is swells after being installed. I could only find at a GM dealer for $7. I would have thought it would be with the pump but was not.
    Also since getting the new pump gas mileage has improved by 5mpg. I have also realized that i do not hear the fuel pump as much as the old , I guess that might be an indication it is going bad.
  2. #2 Re: P0171 Code--Check Fuel Pump
    GM pumps are known for being loud from the factory. Most replacement pumps are quieter. Fuel pressure is one fo the items in the FSM to check with this code.
    Good info, thanks for the reminder in that other thread as well.
  3. #3 Re: P0171 Code--Check Fuel Pump
    PCMO
    That was one of the reasons I got the Bluetooth OBDII reader with the Torque app, I was hoping that it would read the fuel pressure but no such luck.
  1. Hi I'm new and have a p0171 code, can you help?
    By falconjohnd in forum Engine
    Last Post: 12-15-2011, 07:45 AM
  2. p0171 code, AEM WB reads good AFR
    By JayGTP02 in forum General Tech Discussion
    Last Post: 08-14-2011, 12:11 PM
  3. 97 GTP fuel pump code WFP vs. WFL
    By JBONE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2011, 01:13 PM
  4. code P0171 keeps coming back
    By grandprix01 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2009, 01:33 AM
  5. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
