Thread: Installing Heat Exchanger from ZZP
Results 1 to 20 of 21
  1. #1 Re: Installing Heat Exchanger from ZZP
    Donating Users Viperkill97's Avatar
    Arizona
    Well I finally got it installed and have it where the pcm sits, still doesnt pump as strong as i thought it might but it is flowing. I tried to put in the 99+ radiator reservoir, but could've figure out how to get it in place without it hitting the pulley's, so i put a small back up reservoir from auto zone. All that is left is changing the intake, need to find a new way to put on in.
    Life goes by so fast, so why drive slow.
  2. #2 Re: Installing Heat Exchanger from ZZP
    Arizona
    well i will be putting my other pump back on, because it flows better.
  3. #3 Re: Installing Heat Exchanger from ZZP
    Arizona
    Well i found out my old flow jet is bad, so i still have the Bosch gm water pump and need some ideas where to put other than the fog light. does anyone know if it would be better to put the pump upside down or if it is OK to have it on it side.
    I am thinking that i might bolt it right next to the heat exchanger going into it and leaving to go back up. I know that i cannot be the only one that is trying to inter cool their GTP.
  1. cobra heat exchanger?
    By 04boostedindyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2011, 09:00 AM
  2. can in run IC core without heat exchanger?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2011, 04:43 PM
  3. heat exchanger install
    Last Post: 04-03-2011, 04:39 PM
  4. Winter Mode, Heat Exchanger Blockoff
    By 2003 SSEi in forum Visual/Body Modifications
    Last Post: 12-20-2010, 09:00 AM
