Thread: Installing Heat Exchanger from ZZP
Results 1 to 20 of 21
  1. #1 Re: Installing Heat Exchanger from ZZP
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Can you post some pics of the current setup?
  2. #2 Re: Installing Heat Exchanger from ZZP
    iF there's a higher outlet than the other, that's usually the outlet.
  1. cobra heat exchanger?
    By 04boostedindyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2011, 09:00 AM
  2. can in run IC core without heat exchanger?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2011, 04:43 PM
  3. heat exchanger install
    Last Post: 04-03-2011, 04:39 PM
  4. Winter Mode, Heat Exchanger Blockoff
    By 2003 SSEi in forum Visual/Body Modifications
    Last Post: 12-20-2010, 09:00 AM
