Thread: n* and ls1 throttle body questions
Results 1 to 9 of 9
  1. #1 n* and ls1 throttle body questions
    GT Level Member 99GPGTP's Avatar
    Rome GA
    im looking to get either a north star tb or a ls1 tb. looking to get a used one from a salvage yard
    what year and model car/truck do i need to get the ls1 tb off of,
    and what year cadi do i get a n* tb from to still retain cruise
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  2. #2 Re: n* and ls1 throttle body questions
    Rome GA
    nobody willing to help i see
  3. #3 Re: n* and ls1 throttle body questions
    I'd like to help but don't know the years. Maybe searching would help out? I'm sure it's been answered many times.
  4. #4 Re: n* and ls1 throttle body questions
    Donating Users
    MA
    Best advice is go to RockAuto.com and cross reference p/n's. You'll get the list of vehicles the throttle body's are found in and be able to go from there. N* is a 2000+, the 98-99's are different.
    N* P/N for search: 12560099
    Not 100% if the 98-02 LS1's are correct but, LS1 P/N for search: 2172252
    1998 Intrigue - Parted out
    2008 G8 GT - Heavily modded
    2016 WRX STi Limited - Bolt-ons
  5. #5 Re: n* and ls1 throttle body questions
    Rome GA
    thanks i will check that tonight
  6. #6 Re: n* and ls1 throttle body questions
    Minnesota
  7. #7 Re: n* and ls1 throttle body questions
    Apr 2011
    Tally, FL
    Did you find anything? Would this bolt right up with a L36, do i lose cruise control functions?
  8. #8 Re: n* and ls1 throttle body questions
    Minnesota
    Quote Originally Posted by DoubleBlown View Post
    No it won't bolt up to a L36.
    You wouldn't want to bolt it up to a L36 anyway though because you don't need it. If you have a supercharger than people do have adapter plates that would allow you to use it.
    You would also need a new bracket for the throttle and cruise.
  9. #9 Re: n* and ls1 throttle body questions
    Apr 2011
    Tally, FL
    i have a csc so how would use the ls1 throttle body. Do i need a custom made adapter from the L36 to the ls1?
  1. LS1 or N* Throttle Body
    By 2000GTP2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2012, 08:19 AM
  2. Throttle body
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 06:43 AM
  3. N* throttle body
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:41 PM
