Thread: Engine Light on code P0171, IDLE SURGING!
Results 1 to 6 of 6
  1. #1 Engine Light on code P0171, IDLE SURGING!
    SE Level Member balzi's Avatar
    Merrillville, IN
    So... Engine light on and throwing a p0171. Engine running to lean bank 1. SO FAR--- ive checked all vacuum hoses for leaks i could spot with the naked eye: nothing. Changed the MAF (twice), changed the entire CAT assembly (it did have an older leak, that i have been putting off changing but is fixed now), changed the PCV valve, changed the IAC valve, changed the EGR valve, changed the fuel filter, changed BOTH up and downstream 02 sensors, cleaned the TPS (though it was already clean). NOTHING. Cleared the code starts up, and pops right back on.
    PROBLEM: starts right up and runs smooth, after the engine gets warm it begins to surge at idle. I've also noticed a light white smoke from behind the engine down towards the front 02 sensor under the EGR valve area. Something else I cant figure out.
    Ive searched google, youtube, and the forum for other common issues and without getting to deep into the engine itself (little knowledge with), I'm stressed out over what else it could be. ANY HELP OR OTHER TROUBLESHOOTING WOULD BE MUCH APPRECIATED!
    its a 2000 GTP--
    2000 Daytona 500. ADR RSL 18" Rims. Falken Azenis ST115/ soon to be Falken FK452. 245/45/18. K/N Air Filter. Cobalt Autometer Gauges.
  2. #2 Re: Engine Light on code P0171, IDLE SURGING!
    Jul 2011
    Edmonton, AB
    LIM gasket
    Wizaired CAI, ZZP Headers & DP, SLP cat-back, 1.8 RRs
  3. #3 Re: Engine Light on code P0171, IDLE SURGING!
    Charles City, IA
    Sounds like a vac leak. Check all the lines with carb cleaner.
    SMGPFC Two Nipple General
  4. #4 Re: Engine Light on code P0171, IDLE SURGING!
    Merrillville, IN
    I made a videoand posted on youtube... gonna possibly change LIM gasket tomorrow. Any last minute advice. Heres the link.... and how would air be getting out of the engine if it were the LIM?
    2000 GTP engine surge after warming - YouTube
    http://www.youtube.com/watch?v=C7jkXCr-rlM
  5. #5 Re: Engine Light on code P0171, IDLE SURGING!
    Hold off on that LIM.
    You said you searched the forum for your code, therefore you should know exactly what I'd say is your first stop to check.
    Cause...I've said it like a hundred billion times.
    Please let us know when you pull the tube and check it for the crack that we all know it has.
  6. #6 Re: Engine Light on code P0171, IDLE SURGING!
    May 2013
    NORHWEST WASHINGTON
    what tube
  1. Check engine light/code
    By biggt in forum General Tech Discussion
    Last Post: 07-12-2011, 12:09 AM
  2. Sputtering on 98 gtp with no engine light code
    By feonnixxx in forum General Tech Discussion
    Last Post: 04-12-2011, 06:12 PM
  3. Please Help!!! GTP surging idle
    By Damon318 in forum General Tech Discussion
    Last Post: 10-26-2010, 01:05 PM
  4. Surging Through Low Speeds and No Check Engine Light
    By NapNinja317 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-15-2010, 11:06 AM
  5. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
