Thread: Alternator relocation bracket
Results 1 to 13 of 13
  1. #1 Alternator relocation bracket
    Donating Users Viperkill97's Avatar
    Arizona
    Hey all, just installed the alternator relocation bracket in my 97 GTP. Had to convert the tensioner from the 97 style to the 99 style and replace the alternator, but i believe the belts will flow better now.
    But within the next couple of weeks i get to change my head gaskets, i have a small link going into my exhaust, it sucked that i had to take it to a mechanic to find that out, i had no symptoms of a blown head gasket(no water in the oil and no white smoke in the exhaust. )
    so because i need to do this i think i might put my intense stage 4 heads on the block, but a little weary about doing so.
    Life goes by so fast, so why drive slow.
  2. #2 Re: Alternator relocation bracket
    Sooooooooooo..........issue?
  3. #3 Re: Alternator relocation bracket
    Arizona
    so the issue is, how do i a blow a head gasket on a motor with less than 30k miles, never over heated. the only idea i have i have changed my coolant since i put the new motor in.
    also for a daily driver, what do you all think about putting stage 4 heads on, with only a zzperformance stage 2 cam.
  4. #4 Re: Alternator relocation bracket
    Stage 2 cam?
    No idea.
    XP you mean?
    Also...stage 4 heads would be worthless without flow mods really. Just tossing them on a stock car...would it help? Sure...maximizing the gains from them? No.
  5. #5 Re: Alternator relocation bracket
    Arizona
    Stage 2 cam?
    No idea.
    XP you mean?
    The block is stock meaning crank and the pistons. the supercharger has 2.4" pulley and the injectors are the Lucas 42.5. It is inter cooled, but i cannot get the water pump to flow correctly, so i am going to convert back over to the flow jet water pump.and yes the zzp xp camshaft.
    so is it still a waste to put the heads on?
    i would like to put my mp-112 on it, but i could never get the car to run right with the supercharger.
  6. #6 Re: Alternator relocation bracket
    Quote Originally Posted by Viperkill97 View Post
    You have a 2.4" pulley................
    pictures?
  7. #7 Re: Alternator relocation bracket
    Arizona
    Sorry not 2.4" it is 3.0" and here is a picture of the relocation bracket with the supercharger pulley as well.
  8. #8 Re: Alternator relocation bracket
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    Sorry to be kinda off topic but, alt. relocation bracket? Would you be able to run 2 alternators?!?! If so where do I get 1 and what does it look like?!?! Thank you!
  9. #9 Re: Alternator relocation bracket
    Arizona
    Quote Originally Posted by chrishova View Post
    All it does is move the alternator up an inch and back an inch. it allows for the intercooler hose to have more room. i got it from zzperformance.
    and why would you want two alternators, you could just get a more powerful alternator, i also have a powerful system in the car and the seperate battery and more power alternator works great. you may want to change the alternator tensioner bracket to the 99 version.
  10. #10 Re: Alternator relocation bracket
    That is nice! I do have a large case Iraggi 300a alt., 4 runs of 0 gauge wire, also the "big 3" eletrical, and a XS power D3100 in the back, but right now I am waiting for a bracket to fit the large case alt. in. I have a SAZ3500D that is clamped at 3600 watts and up to 4400 watts @ 14.4 volts, so 1 300a alt wont cut it. I will be upgrading to a 5-7k amp in the spring, with the same 15" SMD woofer.
  11. #11 Re: Alternator relocation bracket
    Arizona
    So no thoughts about putting the heads on the car now.
    But i am starting to think that i may not need to change my head gaskets, i was told i have a bad head gasket, but show no signs of having a blown head gasket. i dont have any water in my oil or white smoke.
  12. #12 Re: Alternator relocation bracket
    Sure that you aren't dealing with crappy LIM gaskets?
  13. #13 Re: Alternator relocation bracket
    Arizona
    i am using the metal head gaskets, i believe it is the 4, but it has been awhile since i put them in. but i know that my head gaskets are bad because my coolant has oil in it. DAMN!!!!!!!!
  1. Alternator Bracket
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2010, 01:55 AM
  2. Alternator bracket?
    By Pure2sin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2010, 01:25 PM
