Hi all,
I just picked up an 04 Comp G for my son. Its his first car and one of a dozen Pontiacs I have owned, hopefully that trend continues .
Anyway a few questions. The car has 152k on it. It is a one owner car. The trans was recently rebuilt, new hubs, fuel pump, water pump, tune up, coil packs and intake gasket. I was told the valves, springs, supercharger and pistons where also replaced. Is there anyway to tell if the supercharger is original or aftermarket?
The car does have a few lights on. The famous ABS/TRACTION CONTROL and CHECK ENGINE are both on. With the hubs being replaced I am assuming the ABS control module is bad or there is a loose/broken wire. The original owner told me the light has been on even before the hubs were replaced.
The car stumbles a bit when its started, plus I noticed the supercharger doesn't spool out completely. There was no boost yesterday when I first started it then after a few minutes, presto! boost. Also the car wouldn't immediately drop into a lower gear when I punched it but did when the boost was back. The light comes on and stays on steady which from what I understand that means its an emisssions issue, correct? I need to get the codes pulled to see whats up. The car runs nice and and is tight for the mileage, I can tell it was cared for.
Any thoughts on what I should look for?
