Thread: hard vacuum line replacements?
Results 1 to 3 of 3
  1. #1 hard vacuum line replacements?
    SE Level Member mngtp's Avatar
    Crystal, MN
    Im wondering if any of the hard vacuum lines for the supercharger can be replaced by a plain rubber hose/tube? The line going from the boost bypass value to the t under the blower snout is a two piece line but the part of the line coming off of the boost bypass value broke. I taped it together but it needs to replaced soon. Thanks
  2. #2 Re: hard vacuum line replacements?
    GT Level Member mkyota1's Avatar
    Daytona, florida
    You will be fine as long as you use vacuum hose.
  3. #3 Re: hard vacuum line replacements?
    Apr 2011
    Elk Rapids, Michigan
    You can find the hard vacuum line in bulk at Advanced Auto. They have the rubber fittings too.
  1. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  2. i need a vacuum line
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 04-20-2010, 09:07 PM
  3. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  4. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
  5. Vacuum line...where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 02-25-2009, 11:15 PM
