Thread: '04 GTP Cat removal - Any thing I should look out for?
Results 1 to 8 of 8
  1. #1 Re: '04 GTP Cat removal - Any thing I should look out for?
    Jul 2011
    B-Town, PA
    it may run a "CAT diagnostic" where the PCM will command fuel trims super pig rich and then expect to see a corresponding change in rear O2 readings to see if the cat is there. If it does not see this it will continue to run the test continuously until it does...and if you don't have a cat...you guessed it...your car is basically stuck locked running pig rich. A custom tune can eliminate this from happening. Does your state do a plug in emissions check to read the status of various tests prior to renewing your registration? that may be another issue even with the custom tune as the tune only masks it and keeps the MIL from turning on due to the failed cat check.
  2. #2 Re: '04 GTP Cat removal - Any thing I should look out for?
    Onalaska, WI
    Thanks for the heads up. MN does NOT run emissions, so that's fine. I'm expecting the thrown code. Where is the best place to get the tune done/learn how to do the tune to turn off the diagnostic? Is it a guarantee the diagnostic will continually loop?
    2004 GTP COMP G. Owned since 2006. Daily Driver.
  1. one thing after another
    By gtcoup in forum The Rant Forum
    Last Post: 04-10-2011, 01:10 AM
  2. What is this thing?
    By dpzelenak in forum Visual/Body Modifications
    Last Post: 03-13-2011, 11:22 AM
  3. perhaps the best thing ive ever seen... ever.
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 08-11-2010, 02:54 PM
  4. such thing as bad gas?
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2009, 03:56 PM
  5. Am I doing the right thing?
    By SlowM90 in forum The Rant Forum
    Last Post: 04-24-2009, 07:26 PM
