Thread: Installed headers now problems
Results 1 to 13 of 13
  1. #1 Installed headers now problems
    I just installed headers and now my speedometer doesn't work and my oil pressure light is on. I know i have oil pressure because i loosened my oil filter and started the car......big mess, but i do have oil pressure. not sure what happened. Any input is appreciated. Thanks
  2. #2 Re: Installed headers now problems
    Omaha, NE
    Are all your sensors plugged in?
  3. #3 Re: Installed headers now problems
    I'm pretty sure they are except the 02
  4. #4 Re: Installed headers now problems
    May 2008
    staten island,NY
    the vehicle speed sensor is right to the left of the oil filter, maybe it got saturated and shorted out? get some brake parts cleaner and spray everything down
  5. #5 Re: Installed headers now problems
    I'll check it out after work tom. I'm hoping nothing touched the headers
  6. #6 Re: Installed headers now problems
    I also have a maf code too. would that have anything to do with the o2 being unhooked?
  7. #7 Re: Installed headers now problems
    i also put in my new front sway so maybe i hit some wires?
  8. #8 Re: Installed headers now problems
    Waukesha, WI
    hmm check by the swaybar, i did some damage getting mine in
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  9. #9 Re: Installed headers now problems
    Check the wiring at the trans VSS and oil pressure. It sounds like you hit something pretty well to disconnect that many things. All in the same area.
    You say you have a maf code, but don't tell us which one. Sup with that?
  10. #10 Re: Installed headers now problems
    sorry bill i'll check again lol. going out now to check stuff out.
  11. #11 Re: Installed headers now problems
    i figured it out. i had part of the harness under the header on the rear. Had to cut and solder wires now it's fine just waiting for my o2 extension in the mail and i have to pick up a new o2 because i just broke it trying to pry stuff out of the way.
  12. #12 Re: Installed headers now problems
    Nov 2009
    Grand haven
    we all learned the hard way too. EGTBOK
  13. #13 Re: Installed headers now problems
    i just wish i could learn the easy way once lol
  1. Headers installed last night.
    By Wotgtp in forum General Tech Discussion
    Last Post: 03-25-2011, 05:41 PM
  2. installed headers need help
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 01:49 AM
  3. SD Headers installed and A+++++
    By DCVING in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 06:56 PM
  4. headers installed
    By boostedcompg in forum General Tech Discussion
    Last Post: 12-19-2009, 03:24 AM
  5. ZZP Headers installed!
    By Reptile in forum General Tech Discussion
    Last Post: 03-10-2009, 11:11 AM
