Thread: Tapping noise at idle.
Results 1 to 11 of 11
  1. #1 Tapping noise at idle.
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I changed to Amsoil last oil change. About 1,500 miles later my car started developing this slapping/tapping noise when it is idling. It is loudest at cold idle and can still hear it at hot idle.
    For a few weeks it was doing it everyday, so I took it into the dealership to get looked at. They told me they couldn't hear anything. I took the car home and now it only happens some mornings, not every morning. I can still also hear it sometimes at idle. Sometimes its loud enough at cold idle that I can hear it about 50ft away.
    It seems to be coming from the bottom of my engine. I can't tell if its driver or passenger side but I'm thinking driver side.
    I will have a video of it up as soon as I can. Anyone else have this issue?
    I would like to get this figured out asap because im ready to start modding!!!
  2. #2 Re: Tapping noise at idle.
    Feb 2008
    South Bend, IN
    Also the noise stops if I rev the engine while its idling or start moving.
  3. #3 Re: Tapping noise at idle.
    when my supercharger bearings were goin', i had the same issues!
    almost sounds like a clatter!
  4. #4 Re: Tapping noise at idle.
    Hoffman/Schaumburg, IL
    Don't know if its your prob, but lifter noise is loudest at idle, and goes away as the motor revs up
  5. #5 Re: Tapping noise at idle.
    Oklahoma
    Amsoil. Pffft. Who sold you that crap? Probably cost you like 50hp.
    LOL
    Just kidding. Ive run Amsoil in my GP since I bought it. What filter are you using? Is it the Amsoil EaO29 or some other off the shelf filter?
  6. #6 Re: Tapping noise at idle.
    Feb 2008
    South Bend, IN
    My gp has 35k on it. I dont think its s/c related, hopefully.
    I'm using the Wix filters.
  7. #7 Re: Tapping noise at idle.
    ^i doubt its the s/c w/ that low of miles than.
    i'm just sayin', the bearings do make a clatter sound for the s/c when at idle, and when u start goin', u don't hear it!
  8. #8 Re: Tapping noise at idle.
    Oct 2008
    Horsham, PA
    I also had this problem with my GP. I tried different oils and additives but nothing worked. Eventually I took it to the shop and my intakes were shot. I think it was around $500 fix but could've been more, it was a couple years ago. Haven't had a problem since. Oh by the way and stick with Valvoline or Mobile 1.
  9. #9 Re: Tapping noise at idle.
    Jersey
    check the supercharger oil level?
    16' wrx sti- stock
  10. #10 Re: Tapping noise at idle.
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    possibly it could be a lifter sticking, or a wrist pin giving a piston a little play, this is all common gm problems. there was once a TSB on the wrist pins and GM's solution was to replace 4 of 6 pistons ( cylinders 1-4) it was a joke. on the vortec engines that came in trucks and SUV's, GM's answer for wrist pin cold start ticking was to replace the engines but then they felt that wasnt cost effective so they started doing pistons too for those.
    COMP G
  11. #11 Re: Tapping noise at idle.
    Feb 2008
    South Bend, IN
    Yea after all my research i've decided its probably lifter tick. I just don't drive the car for a few minutes after I have started it until the tick goes away. For my car it seems to be worse when the weather is warmer. Who knows.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  1. SC "tapping" noise... HELP!!
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2008, 05:30 PM
  2. Replies: 5
    Last Post: 05-11-2008, 07:10 PM
  3. Rough/hunting idle
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2008, 11:22 PM
  4. Car runs rich and surges at an idle?
    Last Post: 03-13-2008, 02:54 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
