I have a 97 GTP that I put a new power steering pump in, and the pump has seemed to squeak since the time I put it in. It gets less once the car is warmed up. I am pretty sure its the power steering pump because if I spray WD40 behind the power steering pump pulley, the squeak temporarily goes away, but it always comes back. The belt is new. I probably will have to change out the pump, but anyone know what would cause this and is there a quick fix as opposed to taking off the pump and putting a new one on. I know, that sounds lazy.
