Thread: Grinding sound after installing HAI?
Results 1 to 10 of 10
  1. #1 Grinding sound after installing HAI?
    GTX Level Member blackflag's Avatar
    Virginia
    Recently installed a HAI on my 01 gtp and between idle and 2,000 rpm's the engine is making a light grinding noise. It doesnt sound terrible, but it doesnt sound right. At first I chalked it up to standard engine noise that i couldnt hear with the factory airbox. It seems to fade a little after 5-10 mins of driving. Has anyone else experienced this? Is this normal, or do I need to start trying to diagnose a possible issue? I can post a video tomorrow if the snow lets up.
  2. #2 Re: Grinding sound after installing HAI?
    Omaha, NE
    It's probably just the sound of air coming through the cone filter.
    Or you royally ****ed something major up...
  3. #3 Re: Grinding sound after installing HAI?
    Virginia
    Oh yeah all oil changes and such were done on time. She was very good about maintenance.
  4. #4 Re: Grinding sound after installing HAI?
    Virginia
    I just bought the car from a family member that babied it its whole life. 97k miles. It does have an airflow kind of sound to it but ive never quite heard something like this. maybe a video would help?
  5. #5 Re: Grinding sound after installing HAI?
    its the throttle body's fault.
    The IAC passage was designed to be cheap, not quiet.
  6. #6 Re: Grinding sound after installing HAI?
    Omaha, NE
    Meh, videos don't capture everything. When it's cold it's going to have a sound to it, as long as it goes away when it warms up, you should be alright.
  7. #7 Re: Grinding sound after installing HAI?
    Virginia
    Awesome. So Matt, you know the sound im talking about?
  8. #8 Re: Grinding sound after installing HAI?
    Some call it shovel being dragged over gravel.
  9. #9 Re: Grinding sound after installing HAI?
    Virginia
    as long as its normal....
    thanks for your help!
  10. #10 Re: Grinding sound after installing HAI?
    Indeed.
    Not a problem.
  1. Grinding noise when going 30 and up!
    By rbrown81 in forum General Tech Discussion
    Last Post: 11-06-2011, 08:43 PM
  2. cam grinding
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 11:37 PM
  3. Grinding sound
    By gpgt04 in forum General Tech Discussion
    Last Post: 12-18-2009, 09:18 AM
  4. Grinding Sound
    By Strype in forum General Tech Discussion
    Last Post: 09-02-2009, 01:15 PM
  5. bad grinding sound
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2009, 04:53 PM
