Thread: L36 To A L67
Results 1 to 20 of 31
  1. #1 L36 To A L67
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    My 98 GP GT bottom end went out and it doesn't have a supercharger and I wanted to know what it would take to drop a 3.8 with a supercharger on it.
    Is there extra wiring mine doesn't have?
  2. #2 Re: L36 To A L67
    the boost bypass vavle and the 2 bar map sensor. you can get the wiring harness connectors from ZZP as a kit.
  3. #3 Re: L36 To A L67
    Jun 2011
    Watertown, SD
    Thats all i'll need?
    Any reprogramming?
  4. #4 Re: L36 To A L67
    you need to have an L67 file in the PCM or it wont know what the hell is going on when you go into boost.
  5. #5 Re: L36 To A L67
    Jun 2011
    Watertown, SD
    So when i go pick the motor yup grap the pcm too and swap them out
  6. #6 Re: L36 To A L67
    gonna need a tune anyway because the transmission files are different.
  7. #7 Re: L36 To A L67
    Basically...it isn't all just swap and go.
  8. #8 Re: L36 To A L67
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    i just swapped you will also need the fuel pump and a fuel pump hot wire kit. the gts dont have a strong enough fueling system to support the l67 mine has been knocking like hell every since i put it in. i just ordered a 255 lph walbro pump and a fuel pump hot wire kit to get 13.5 volts to the pump. there are lots of hickups people just forget to mention so if you need any help pm me.
  9. #9 Re: L36 To A L67
    Jun 2011
    Watertown, SD
    The way its sounding l'll just live with a L36, I really don't have the time to tinker with it...daily car
  10. #10 Re: L36 To A L67
    probably your best bet if you dont have the time and money to commit. I modded mine quit a bit when I put it it in but it is still not nearly as plug and play as everyone makes it sound. I am speaking from experiance.
  11. #11 Re: L36 To A L67
    thunder, you needlessly changed the fuel pump. the GT pump is just fine. i ran one down to a 3.2 pulley with no ill effects. my fuel pressure was solid.
  12. #12 Re: L36 To A L67
    Grand Island, Nebraska
    Maybe his pump was bad and he just needed a new one?
  13. #13 Re: L36 To A L67
    Jun 2011
    Watertown, SD
    Ok I sleeped on it and I've made up my mind, I want to swap, I'll just drive my Astro.
    Can someone that has done this tell me what all I'm going to need\do.
    When I go get the motor on Monday, I will be getting the whole motor, engine wiring, pcm, I'll be buying a new f/p
    Anything else?
  14. #14 Re: L36 To A L67
    W Body Store
    You dont need a fuel pump unless yours is going bad. You will also need an aftermarket tune because the transmission in the GT has 3.29 gears and the PCM is from a GTP with 2.93 gears.
    Also any gaskets that you will need for replacing the engine.
  15. #15 Re: L36 To A L67
    Jun 2011
    Watertown, SD
    My pump was just replaced. Do I still have to buy that kit you linked to if I'm going to be getting the whole wireing harness?
    And besides programing the pcm for the trans i'm good to go
  16. #16 Re: L36 To A L67
    Actually thats my bad, you probably dont need that wiring kit. Im not going to say youre good to go because i dont know everything and i havent done it before. keep researching.
  17. #17 Re: L36 To A L67
    Jun 2011
    Watertown, SD
    Well it sounds pretty straight forward since I'll have the org wireing\pcm from the supercharged GP.
    we'll see what others say
  18. #18 Re: L36 To A L67
    you either need a gtp wiring harness or the wiring kit for your bbv valve and map sensor. The reason i changed my fuel pump is I was only getting 42 psi to the rail and mine was pulling 10 deg of knock at wot. i changed the filter fuel pressure regulator and went to a gtp pump which was apperantly weak as well and still got 42 with the key on engine off. If you need a tune call john at intense racing they do them for 170 with free unlimited upgrades it is by far the least expensive option out there and they answer the phone when you need help.
  19. #19 Re: L36 To A L67
    Jun 2011
    Watertown, SD
    Ok thanks i'll be calling john, got my motor today but with 98 deg heat im not touching the car
  20. #20 Re: L36 To A L67
    Quote Originally Posted by grandamle91 View Post
    Cmon you woman...get out there and sweat your ballz off.
    LOL
l36, l67
