Thread: bad gas mileage and trans temps high
Results 1 to 20 of 28
  1. #1 bad gas mileage and trans temps high
    GT Level Member NR92's Avatar
    Atkins, Ia
    had this in another thread but i figured i would start one just for the issue
    anyway 04 GP gtp comp G with 113k miles it gets pretty sad mpgs even though i drive about 80% highway at 70mph and at that speed while not beating on it the trans temps get as high as 225 * consistently i would say 90% of the time that the transmission is warmed up it is over 200*
    i just cant figure out the issue, its about to get headers, new o2 sensors and a highflow cat and i hope that helps
    so far i have replaced
    plugs (factory replacements) and wires (bosch lifetime warranty)
    changed supercharger oil
    k&n cone filter
    transmission filter and fluid (merc 3?)
    fuel filter
    took the throttle body off and cleaned it to the point of being almost spotless
    cleaned the mass air flow sensor with electronic parts cleaner
    tires are about 5k old with 35ish psi
    if it matters the car says the alternator is charging well (between 13.8-14.5 volts)
    coolant is still dexcool but still looks bright orange/red
    car no engine lights on
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  2. #2 Re: bad gas mileage and trans temps high
    SE Level Member Thuglife2334's Avatar
    Apr 2011
    CT
    yeah man mean seems to run that high to the tranny temp.. hey want headers u looking to get??
  3. #3 Re: bad gas mileage and trans temps high
    Atkins, Ia
    thinking speed daddy
  4. #4 Re: bad gas mileage and trans temps high
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Tranny coolant temps are susually around 200 range easily. On these hot days I get around 215 or so. If im correcnt I head somewhere around here above 220* is when you need to worry.
    And what do you mean by crappy MPGs?? cause i drive alot of highway and my average (as calculated by DIC) is still onle 22ish because of how I drive in the city.
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  5. #5 Re: bad gas mileage and trans temps high
    Nothing you have done or seem to be planning are going to change transmission temps.
    The trans temp is related to clutch slipping and the amount of cooling that the super small cooler in the side of the 180-195F radiator provides. Not sure where you get the idea that modding will help trans temps, you may want to consider an aftermarket cooler.
  6. #6 Re: bad gas mileage and trans temps high
    Atkins, Ia
    i figured changing the fluid and filter would help, the rest of it was to rule out issues for the lesser then expected mpgs
  7. #7 Re: bad gas mileage and trans temps high
    Atkins, Ia
    Quote Originally Posted by tayl5645 View Post
    well when i went to Florida, i got 22mpgs with the a/c off and the cruse on around 70mph and i didnt get much better on the way back, right now without really beating on it my average says 19.6mpg, i understand its gonna go down if i beat on it but it seams it stays around there wither i bet it or not
    what i am getting at is people on here say these cars can get 30mpg on straight highway and i am getting 22mpgs, dont get me wrong i understand its a full size car but i feel theres something wrong
  8. #8 Re: bad gas mileage and trans temps high
    Jul 2010
    Michigan
    I mainly get 25s no where near 30s wish I did. Also the older it get the less likely you are to get the fresh MPGs.
    2005 GTP Grey
  9. #9 Re: bad gas mileage and trans temps high
    The Boss Iceman6669's Avatar
    Jun 2011
    Mine is a 97.. granted series 2 not 3. But I can get 24-27 everyday driving.. And that is with me driving it like i stole it. Pure highway I can break 30. I got a buddy who has one... Drives like a grandpa.. And he gets 30+ everyday driving...
  10. #10 Re: bad gas mileage and trans temps high
    Jul 2010
    Michigan
    Quote Originally Posted by Iceman6669 View Post
    Are we speaking SE GT or GTP... each one is gonne be completely different I would think it would be pretty hard to muster 30+ on the supercharged with regular driving
    2005 GTP Grey
  11. #11 Re: bad gas mileage and trans temps high
    Jun 2011
    Both Mine and his are GTP....
  12. #12 Re: bad gas mileage and trans temps high
    Atkins, Ia
    is it the gtp's or the gtp comg G's that have the different gear ratio in the trans that supposedly allows for slightly better mpgs
  13. #13 Re: bad gas mileage and trans temps high
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    pretty sure thats the comp but dont quote
    Smgpfc
  14. #14 Re: bad gas mileage and trans temps high
    2.93's will net better mpgs than 3.29's in the comp g trans
  15. #15 Re: bad gas mileage and trans temps high
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    The mileage does seem low too me. With my mods I'm getting around 19-21 mostly city and highway is 29. In town I usually shift at 2500 rpm.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  16. #16 Re: bad gas mileage and trans temps high
    Atkins, Ia
    thats what im saying, the only thing i can think of is a lazy o2 sensor or a bad cat that just hasnt thrown a code yet
    now i know this is a long shot and the question will make me sound like a noob but can a clogged cat that is causing a restriction transmit heat though the engine and into the transmission causing the trans temps to run hot? it sounds far fetched but its something i wondered about
  17. #17 Re: bad gas mileage and trans temps high
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Quote Originally Posted by NR92 View Post
    Not likely.
    Is your TC still locking up?
  18. #18 Re: bad gas mileage and trans temps high
    Atkins, Ia
    as far as i know, its not throwing a code or going into safe mode (if these cars have that)
  19. #19 Re: bad gas mileage and trans temps high
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Maybe it's time for seafoaming...don't know what the problem could be though. I get crappy mileage as well, but my average speed is 20mph since I work with my car on patrol. On highway it doesn't drink though, thank god!
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  20. #20 Re: bad gas mileage and trans temps high
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    You guys who live where it's flat have it easy! Granted I have 148K miles but I am lucky to get 23MPG regularly and all highway I get 25 MPG. I have a tune, HV 3, open cone and 3" downpipe. Mine's a GT.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  1. crazy high trans temps or no temps!? pics!
    By blknbstd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2011, 06:07 AM
  2. High Mileage
    By jetscrazy44 in forum The Rant Forum
    Last Post: 08-02-2010, 06:19 AM
  3. 1997 GT High Mileage Cold Air Intake
    By Nick22 in forum General Tech Discussion
    Last Post: 06-26-2009, 12:34 AM
  4. Tune Up Advice, Just bought High Mileage Grand Prix GT
    By anicolay in forum General Tech Discussion
    Last Post: 04-29-2009, 02:57 PM
  5. high mileage trans issues
    By 01whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2008, 08:23 AM
