Thread: Oil Problem
Results 1 to 14 of 14
  1. #1 Oil Problem
    SE Level Member Enzo354's Avatar
    USA
    Well I replaced my valve cover gasket hoping to fix my issue, but I still am getting oil blown over my engine. It seems after long enough pressure builds up and blows oil out of the dipstick tube onto the valve cover/ headers. Whats doing this?
  2. #2 Re: Oil Problem
    clogged pcv valve.
  3. #3 Re: Oil Problem
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Check the PCV valve. Matt beat me to it...
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Oil Problem
    ^^3rd^^^..take out the value and shake it and see if it rattle's
    SMGPFC Member #10
  5. #5 Re: Oil Problem
    Charles City, IA
    4th.
    SMGPFC Two Nipple General
  6. #6 Re: Oil Problem
    USA
    Thanks everyone I checked it and it still rattles. I put it back together and Ill try it tomorrow, maybe it got stuck. I'm going to pick up a new one anyway in the morning. Having oil blow out like that is ridiculous so I hope this works.
  7. #7 Re: Oil Problem
    Omaha, NE
    Hey Brock, I found your problem... You topswapped in Nebraska.
  8. #8 Re: Oil Problem
    Grand Island, Nebraska
    Not this^
  9. #9 Re: Oil Problem
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Heeeeyyyyyy, not funny!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  10. #10 Re: Oil Problem
    USA
    Thats only half of my issue lol. I rigged up a valve cover breather till I can get a valve :/ Worked well.
  11. #11 Re: Oil Problem
    Hagerstown,Md
    Sounds like you might have blocked your PCV passage
  12. #12 Re: Oil Problem
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    ^^^^^^^ This
    If you solved you're problem by putting a breather on the valve cover than you have blocked your PCV system somewhere during your install.
    For all your 3800 needs:
  13. #13 Re: Oil Problem
    USA
    I did my swap and had it done back in december. I went about 6k miles so far and it just started doing it.
  14. #14 Re: Oil Problem
    PA
    Quote Originally Posted by Enzo354 View Post
    So you are saying there is no way you blocked a PCV passage? Because all your symptoms point to that.
    2001 GSE
  1. BCM Problem?
    By campbech in forum General Tech Discussion
    Last Post: 01-09-2013, 01:51 AM
  2. '98 gtp ecu problem?
    By cbledge in forum Engine
    Last Post: 02-10-2011, 09:07 AM
  3. HID Problem
    By Dthreap in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2009, 05:05 PM
  4. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
  5. well now its a problem...
    By the1euge in forum General Tech Discussion
    Last Post: 10-26-2008, 01:43 AM
