Thread: Power Steering Pump Squeaking
Results 1 to 6 of 6
  1. #1 Power Steering Pump Squeaking
    Apr 2011
    Gainesville, FL
    I have a 97 GTP that I put a new power steering pump in, and the pump has seemed to squeak since the time I put it in. It gets less once the car is warmed up. I am pretty sure its the power steering pump because if I spray WD40 behind the power steering pump pulley, the squeak temporarily goes away, but it always comes back. The belt is new. I probably will have to change out the pump, but anyone know what would cause this and is there a quick fix as opposed to taking off the pump and putting a new one on. I know, that sounds lazy.
  2. #2 Re: Power Steering Pump Squeaking
    if its squealing and hard to turn, its over johnny! hes the how to http://www.grandprixforums.net/power_steering_pump.php
    edit: i just re read and you say you replaced it already and its squealing, it may be a bad pump, how long ago did you buy it and was there a warranty?
    hard to the left usually means its time for a rack and pinion, my pump and rack both went out at the same time it would seem.
  3. #3 Re: Power Steering Pump Squeaking
    Apr 2011
    Gainesville, FL
    OK. I replaced the power steering pump today and it is still chirping from the belt area. So, the power steering pump is new, the belt tensioner is new, I had the water pump off within the last two months and it seems ok. The harmonic balancer is new. Both the supercharger and drive belts are new. The other idler pulleys seems to turn fine and don't feel like anything is wrong with them. Could this result from crud on the pulleys themselves? I have been spraying WD40 around to try to find where they chirp is coming from. It seemed to go away when I sprayed down by the power steering pump, but maybe it was just getting on the belt? If thats the case, why would the chirp go away?
  4. #4 Re: Power Steering Pump Squeaking
    the wd-40 is lubing the belt, so it wont squeak till it burns off.
    if the groves in your pulleys are full of crap. you can clean them with a scrub brush and soapy water, and rinse them off.
    or if it still squeaks after cleaning them, maybe try some belt dressing.
  5. #5 Re: Power Steering Pump Squeaking
    Apr 2011
    Gainesville, FL
    I think I fixed it. A few months back when I was working on the water pump, I broke a bolt from the power steering pump off in the engine block. Two shops tried to get it out but couldn't. They actually ground down some parts of the block upon which the power steering pump sits. After I managed to get the broken bolt out myself, I tried to build the areas back up with JB weld, but I guess I did not do a good job, as when I looked closely at the power steering pump today, the pump was tilted somewhat causing the pulley to not be completely in line with the rest of the pulleys. I used an aluminum plate behind the pump and now it sits properly and there is no noise yet. Fingers crossed.
  6. #6 Re: Power Steering Pump Squeaking
    St. Louis
    That should take care of it. You were causing the belt to not ride squarely across the pullies, hence it squeaked. Just dealt with this on my Bonne.
  1. Power Steering Stiff After New Pump
    By brandonl2000 in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 01:05 PM
  2. 99 GT power steering pump
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-10-2011, 11:13 PM
  3. Need New Power Steering Pump?
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-05-2010, 01:59 PM
  4. power steering pump
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 04:26 PM
  5. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
