Thread: Bad coolant elbow
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Bad coolant elbow
    They might not know how best to do them. I had an admin on a 3800 board once pull the LIM and UIM back off a car to replace an elbow. I said, "or you could have taken this one thing off". It was not a happy day for that guy.
    Take that link and maybe give it a try. Or take that to them, say "BillBoost says it takes less than an hour for anyone." One hour of labor plus $4 elbows from the parts store and coolant.. poof.
  2. #22 Re: Bad coolant elbow
    if you pop the lim off, the lower elbow is not changed, and thats 1/2 the job.
  3. #23 Re: Bad coolant elbow
    Jul 2010
    Toledo OH
    Just to clarify, this applies for a 2004 GP?
  4. #24 Re: Bad coolant elbow
    yes, all 97 and up 3800 engine GP, regal, bonnies, monties. and so on.
  5. #25 Re: Bad coolant elbow
    Slower, Lower Delaware
    I live in Delaware. At $1002 I'll come to Ohio to replace an elbow.
  6. #26 Re: Bad coolant elbow
    Jun 2013
    NC USA
    I just did mine. Started losing coolant a couple of weeks ago and gradually got worse. I thought it was the water pump at first, but closer inspection revealed the leakage was coming out of the intake/elbow joint. Dorman/HELP makes metal ones now, part no. 47065HP. $12 a pair at Advance Auto. The job was fairly easy as such things go. The only difficulties were getting the broken plastic ends out of the holes, and getting the air bled out afterward. It's all good now.
  7. #27 Re: Bad coolant elbow
    I pulled mine out and broke them when I did my rockers, replaced them with metal. Pulled them off again to do my I/C, no problem, they went right back in. metal FTW!
  8. #28 Re: Bad coolant elbow
    GT Level Member aligater's Avatar
    london ontario canada
    Say it'll take you an hour. FWIW it only takes two hours if you live in Canada.
    If you had our beer you'd understand, Eh?
    Things take longer when you are close to the north pole.
    It's more like a brass pole, and they do dance longer. And in Canada nudity really means NUDE!
  9. #29 Re: Bad coolant elbow
    Correction 95 and up 3800 engines. Oldsmobiles had the Series II in 95 as did the Bonnies.
  10. #30 Re: Bad coolant elbow
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    FWIW it only takes two hours if you live in Canada. Things take longer when you are close to the north pole.
    Ya but are car go faster with that cool dense air
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  1. new coolant elbow loose ?
    By rustang92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2010, 09:37 PM
  2. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  3. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
  4. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
  5. Coolant Elbow Replacement on a 99-00 GTP?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 08:01 AM
