Thread: L36 TB and valve covers same as L67?
Results 1 to 14 of 14
  1. #1 L36 TB and valve covers same as L67?
    SE Level Member 97PAGTP's Avatar
    May 2011
    Williamsport, PA
    Can anyone tell me if the L36 (non-supercharged 3800) throttle body and valve covers are the same as the L67? My dad has a spare L36 sitting in his shop and if they were the same, I was going to try porting the TB and maybe smoothing out the valve covers for on my 97 GTP.
    Thanks!
    1997 Dark Teal GTP coupe, Magnaflow highflow cat, Borla mufflers w/ Magnaflow tips, Wizaired, LS1 crossed drilled/slotted fronts, stock crossed drilled/slotted rears, tinted tails, clear corners, triple pod w/ Glowshift gauges, STB, chrome grilles, junk transmission, 200k+ miles...
  2. #2 Re: L36 TB and valve covers same as L67?
    Grand Island, Nebraska
    They are not the same. I think the bolt holes might line up on the throttle bodies but they are different. the valve covers are also different (I think there are little spaces for the injectors since they are in the heads on the GTP)
    The only thing thats the same is the block (except for compression)
  3. #3 Re: L36 TB and valve covers same as L67?
    TB's are the same bolt pattern, but the L36 TB is much smaller. And yes, the VC's have a different bolt pattern since the injector bosses are in the heads on the supercharged cars and the N/A ones are in the LIM.
  4. #4 Re: L36 TB and valve covers same as L67?
    May 2011
    Williamsport, PA
    Thanks for the help!
    The MAF sensors are the same though, correct?!? For the 97-98 models.
  5. #5 Re: L36 TB and valve covers same as L67?
    Right...but the '99+ MAF's are different IIRC.
  6. #6 Re: L36 TB and valve covers same as L67?
    May 2011
    Williamsport, PA
    I hate to change the subject, but atleast its a thread I started. Do you know the boost difference between a 3.4 and 3.5 pulley? I know stock 3.8 is around 7.5-8.
  7. #7 Re: L36 TB and valve covers same as L67?
    Quote Originally Posted by 97PAGTP View Post
    Every car is different...you won't know until you have a real boost gauge that tells you what your running.
    My buddy had over 13psi on a 3.4" with a ported blower/tb/fwi/tune/PEM's/3" DP
    I had 10-11psi on a 3.25" with an XP and headers and other junk...so...
    yeah.
    btw...most stock GTP's tend to sit around 5-7psi stock.
  8. #8 Re: L36 TB and valve covers same as L67?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    It depends on mods. I was seeing 8-9 psi on a 3.4 and like 7 on a 3.5
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: L36 TB and valve covers same as L67?
    i wouldnt drop pulleys on just a 3in dp.
  10. #10 Re: L36 TB and valve covers same as L67?
    you could probably get away with a 3.5. You'll never know until you try.
  11. #11 Re: L36 TB and valve covers same as L67?
    Topeka, KS
    That buddy twas me and it was actually 14psi of boost on a good day
  12. #12 Re: L36 TB and valve covers same as L67?
    That buddy wasn't you...
    It was Kevin's car.
    And he saw over 15 a few times in the cold. Then it popped.
  13. #13 Re: L36 TB and valve covers same as L67?
    May 2011
    Williamsport, PA
    Thanks guys. I have full 3" exhaust, Wizaired, 180* tstat, and will have a tune and AL 104s before pulley goes on. Pulley is actually being installed on the dyno, right before dyno tuning.
  14. #14 Re: L36 TB and valve covers same as L67?
    Good deal. Let us know the numbers
  1. Valve covers!!
    By Ttypel67 in forum General Tech Discussion
    Last Post: 06-10-2010, 10:51 PM
  2. rwd l36 valve covers fit fwd l36
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2010, 02:52 PM
  3. zzp valve covers
    By rodman in forum Turbo
    Last Post: 08-30-2009, 04:20 PM
