Thread: Stock crossover is short???
Results 1 to 2 of 2
  1. #1 Stock crossover is short???
    SE Level Member 98RegalGS's Avatar
    Victorville, CA
    Chats
    I just replaced the lower intake gaskets and valve cover gaskets on my 98 Regal Gs. I decided to replace the crossover doughnut gasket while I was in there. It seems like the stock crossover pipe is too short when I try to put it back on. On the back side it has an inner pipe that goes into the rear manifold. If I bolt the front first, the back seems to be short and vice versa. Is there a proper installation procedure? Front first or back first? Anyways, now I have an exhaust leak at the back. Damn it I should have left the old gasket in there.
    98 Regal Gs L67 SC. 3.4 Pulley, SLP CAI, 3" downpipe with no u-bend, resonator delete, TB spacer, TB heat shield, 17" Caddy CTS wheels.
  2. #2 Re: Stock crossover is short???
    Chats
    98246
    If it wasn't broke, you learned a lesson.
    Start both at the same time. Then torque evenly.
  1. Crossover
    By Blownl36 in forum Turbo
    Last Post: 08-17-2010, 07:08 PM
  2. Long story short - want to get back to stock exhaust
    By OmahaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2009, 08:56 AM
