Thread: gen 5 swap
Results 1 to 4 of 4
  1. #1 gen 5 swap
    GT Level Member nicks98gtp's Avatar
    michigan
    found a great deal on a gen 5 kit, and i was curious as it the gen 5 intake would bolt up to the l67 heads? and anything else i would have to do to run the gen 5 setup on a basically stock l67?
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: gen 5 swap
    Donating Users
    South Deerfield, MA
    Yes, it will bolt up. You will need an adapter to bolt your throttle body up to the Gen V and you will have to modify the evap to work with it or delete it.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: gen 5 swap
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    There is a good thread over at clubgp about the gen V swap
    For all your 3800 needs:
  4. #4 Re: gen 5 swap
    Charles City, IA
    all you have to do is plug the evap hole on the gen v and run a hose from the pcv nipple to fresh air after the maf sensor.
    SMGPFC Two Nipple General
  1. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  2. Top Swap
    By mikejon in forum General Tech Discussion
    Last Post: 03-13-2010, 02:30 PM
  3. 97 DIC swap ?'s
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2009, 01:35 PM
  4. DIC Swap Help
    By cboth686 in forum General Tech Discussion
    Last Post: 01-01-2009, 09:14 PM
