Thread: intercooled people
Results 1 to 20 of 32
  1. #1 intercooled people
    Waukesha, WI
    what are you guys running for rails?
    im going with 2in core and gen V.
    i dont see anyreason to spend 500$ on PRJS/zzps logs.
    was looking at WBSs modded rails, need opionions.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: intercooled people
    APPARENTLY i have ZZP rails.
    but i got them from WBS.
    Who knows.
    mike stopped posting on here a while back.
    WBS flex line is way too long, has to sit sideways and rubs the hood insulation.
    I honestly vote PRJ's with an aeromotive FPR.
    best of everything.
    best logs, no hood clearance issues, and a much better than stock FPR.
  3. #3 Re: intercooled people
    Quincy, Mass
    i have PRJs now, they rock.
    i had ZZP modded rails, they had a leak where the fuel lines connected to rail unless it sat just right, i used the vac line coming from my TB to hold it there. i only replaced them because i got an awesome deal on the PRJs from local.
    No more GP 04 Impala SS Indy:
  4. #4 Re: intercooled people
    I should note I have a 90* on the return and a straight connector on the send.
  5. #5 Re: intercooled people
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I used to run ZZP fuel logs, they were nice, never had a problem with leaking.
    I did hear that PRJ wasn't making his fuel logs anymore though, so I picked up a set..........they are amazing!!!!!!!!!!!!
    Hey Matt, have a link for that FPR???
    For all your 3800 needs:
  6. #6 Re: intercooled people
    aeroforce recommends the following for use with their fuel rails (which someone has said recently they do not fit)
    Aeromotive | 13101 - A1000 Injected Bypass Regulator
    Aeromotive | 13109 - A1000-6 Injected Bypass Regulator
    Aeromotive | 13105 - Compact EFI Regulator
    I'd suggest the last one unless you wanted to get into multiple fuel pumps...
  7. #7 Re: intercooled people
    Orange County, NY
    What don't fit?
  8. #8 Re: intercooled people
    aeromotive rails.
    I've seen one comment on here claiming that.
  9. #9 Re: intercooled people
    Vancouver, WA
    I just have a self modded fuel rail (cut with 5/16" fuel injector hose and fuel hose clamps). The connection part of the fuel rail touches the hood which causes a lil vibration but I don't mind.
    Slowest 'Cooled Gen V ever
  10. #10 Re: intercooled people
    Waukesha, WI
    pics footballplaya?
    i was kinda thinking on doing something like that
    RayRay
    92 Turbo miata
    02 lexus is300
  11. #11 Re: intercooled people
    Vancouver, WA
    Don't have any but I'll take you some
  12. #12 Re: intercooled people
    Waukesha, WI
    appreciate it
    im going for pretty, just funtional on this car
    RayRay
    92 Turbo miata
    02 lexus is300
  13. #13 Re: intercooled people
    Orange County, NY
    I like that compact unit aeromotive has, but I'm at a loss as where I would mount it........it looks kinda big!
  14. #14 Re: intercooled people
    add to MAP bracket?
  15. #15 Re: intercooled people
    Vancouver, WA
    Quote Originally Posted by redlinepontiac View Post
    appreciate it
    No problem. Then what I have is what you need lol.
  16. #16 Re: intercooled people
    Orange County, NY
    add to MAP bracket?
    Hmmm, that means I'd have to put it back on
    I was thinking maybe put it on the STB???
  17. #17 Re: intercooled people
    no.
    that would weaken it.
  18. #18 Re: intercooled people
    Orange County, NY
    Bahhhh, how much stress would it really put on it?
  19. #19 Re: intercooled people
    none.
    It would weaken it, thus could snap if you decided to be the snot out of it.
  20. #20 Re: intercooled people
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    installed my zzp fuel rails today for the first time and they leaked as soon as i primed the car up. All is good now though. Just had to do some tightening.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  1. Tools to cut bumper frame off (Intercooled People)
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 10:33 PM
  2. Intercooled front bumper
    By gtpsleeper in forum Visual/Body Modifications
    Last Post: 04-19-2009, 01:42 PM
