Thread: ribbed for my pleasure.....
Results 1 to 5 of 5
  1. #1 ribbed for my pleasure.....
    andover
    what is the advantage of upgrading to an 8rib pulley setup?
    and when do i do it? is there a certain point in modding where it is needed?
  2. #2 Re: ribbed for my pleasure.....
    Pennsylvania
    Do it because you have belt slip, not as a preventative measure. If you don't have belt slip, don't worry about it. The additional weight over a 6-rib will (theoretically) get you slightly worse gas mileage, although if you got them done in billet aluminum, it might be about the same as the stocks.
  3. #3 Re: ribbed for my pleasure.....
  4. #4 Re: ribbed for my pleasure.....
    Bunnell, FL
    who did i just see w/ a 10 rib?
    or you could go w/ the cogged setup
    I'm a Sex Offender
  5. #5 Re: ribbed for my pleasure.....
    H body + 8 rib + belt wrap= no belt slip ever.
    Or just run with it till you have an issue.
