Thread: Tools to cut bumper frame off (Intercooled People)
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Tools to cut bumper frame off (Intercooled People)
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by 01gpgt01 View Post
    You're also going to want to use a sawzall or a die grinder, for cutting the support. A dremel will take a year of sundays lol.
    ^ This.
    I'm not lowered,almost tore the fmhe and my front end off backing out of my friends driveway.
    So we cut the bumper support on mine.
  2. #22 Re: Tools to cut bumper frame off (Intercooled People)
    When looking at the cut supports and thinking about it. How much airflow are you getting behind the plastic cover?
  3. #23 Re: Tools to cut bumper frame off (Intercooled People)
    Quincy, Mass
    bill cutting the bumper allows you to put the front air dim back on which will direct the air right into it.
    mine hung done over an inch below the bumper and it looked awful. the first driveway i pulled in it just touched and bent it the slightest bit.
    that zzp one in the last pic looks smaller. you should definitely cut the bumper bar and raise up the fmhe if it hangs below the bumper.
    No more GP 04 Impala SS Indy:
  4. #24 Re: Tools to cut bumper frame off (Intercooled People)
    W body FTL
  5. #25 Re: Tools to cut bumper frame off (Intercooled People)
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  6. #26 Re: Tools to cut bumper frame off (Intercooled People)
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    Plasma cutter??
    I know not everyone has a plasma cutter but takes about 1 min with one though.
    Do not use a dremal, you will be there for ever. Sawzall will work, but will go through a couple of blades, but it will work. Those bumbers are semi hardened, so it will chew up blades.
    What ever you use, be safe and wear some type of eye protection.
  7. #27 Re: Tools to cut bumper frame off (Intercooled People)
    Bowie, MD
    I took it to my friend who works at toyota and he used a die grinder. took no time at all.
  8. #28 Re: Tools to cut bumper frame off (Intercooled People)
    Waukesha, WI
    actually the supports are HSS ( high strenth steel) try and bend one
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  1. Intercooled front bumper
    By gtpsleeper in forum Visual/Body Modifications
    Last Post: 04-19-2009, 01:42 PM
