Thread: supercharger question
Results 1 to 5 of 5
  1. #1 supercharger question
    SE Level Member shawnrandolph's Avatar
    michigan
    Okay I put a lashlight inside the blower on the inlet to check if the little boost bypass butterfly was airtight on my gen v and I could see light right on the sides. So i adjusted it closed all the way but theres still light from when the valve opens and closes it rubs on the walls. Will this create enough of a boost leak when under boost to be concerned with or is just about all of them like this. I checked both my gen III's and both were even worse but when on the car they worked great.
    So would I just loose like a psi then pulley down and forget or should I replace the brass butterfly
    ported polished gen v, Ahcohol Injection Systems comp. trunk mount stg. 2 meth, 42lb 3" pulley headers built trans, xp hot cam
    blower port and outside polish pm me
  2. #2 Re: supercharger question
  3. #3 Re: supercharger question
    michigan
    It looks as though it has rubben away a little. So your saying Bio that it shouldnt be air tight or really close when closed all the way.
    Thanks Bio
  4. #4 Re: supercharger question
    none of them are perfect. youll produce boost just fine.
  5. #5 Re: supercharger question
    michigan
    Thanks Bio your always there to help
  1. supercharger question
    By Lougp05 in forum General Tech Discussion
    Last Post: 01-08-2011, 12:21 AM
  2. new supercharger question
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 09:49 AM
  3. Supercharger question
    By l3enner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 09:39 PM
  4. Gen 3 Supercharger Question?????
    By gtpracer0186 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 10:02 PM
  5. supercharger question
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2008, 02:34 PM
