Thread: Solvent tank+SC case = ?
Results 1 to 4 of 4
  1. #1 Solvent tank+SC case = ?
    Grand Island, Nebraska
    I have access to a solvent tank that I am going to put my heads in. Is it okay to put the SC case in there? I assume the grease in the bearings is going to go be useless afterward. Do I need to remove the bearings? If so how do I go about this and putting new grease in?
  2. #2 Re: Solvent tank+SC case = ?
    Don't clean the inside of the case. By removing the carbon build up in the compression chamber you'll reduce the sealing of the SC a slight bit. As for the bearings. When I work on a charger, I duct tape over them.
    Removal is either done with a blind pilot bearing tool or you drill and tap them under neath and use a grease gun to push them out.
    Rotor Bearing Replacement
    Tools
    Drill and tap the red holes (pic is after greased them and removed)
    Thread your NPT pipe in and hook to grease gun
    Pump until the bearing pops out.
  3. #3 Re: Solvent tank+SC case = ?
    Thanks for the helpful response.
    Well see, I just ported it and I sealed of the bearing holes, but there is aluminum dust everywhere. Is there another way to get it off/out?
  4. #4 Re: Solvent tank+SC case = ?
    A quick rinse with water.
  1. Gas Tank?
    By BlackSun in forum General Tech Discussion
    Last Post: 11-18-2010, 01:45 PM
  2. Gas tank removal
    By daveg in forum General Tech Discussion
    Last Post: 09-09-2009, 05:17 PM
  3. gas tank?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 05-11-2009, 06:19 PM
  4. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
