I check other Posts and added to one but getting no replies so I will open this one;
I guess I got My BT interface / Torque reader just in time. Check engine light with the p0304 #4 misfire. After resetting will only come up if I accelerate hard / load up motor. Engine will "bump" "hesitate" what every you want to call, it a bit loading up ...on an incline trying to maintain speed or accelerate. If I down shift and get the RMPs up it smooths out. MPGs no change and normal on start, idle, and easy driving. 170k and R&R LIM, UIM, TB gaskets, plugs, coolant, oil 1200miles ago. Did a 0-60 check about 300 miles ago and was 6.7s. No mods. engine clean. 190 tstat and OBD says 199-210f with ac and 90f temp. Vac lines being shipped. SO I guess Injectors or ECM? I disconnected battery over night no change. almost forgot. MAF sensor changed 10 mo ago.
