Thread: gen v swap
Results 1 to 5 of 5
  1. #1 gen v swap
    Waukesha, WI
    eveyone that has a gen v is running a n*, is anyone running a ported L67 TB on their genv?
    would i need to hook any extra lines up for the PCV to be functional still?
    or is all the vac lines the same and just drop it in and go
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: gen v swap
    Charles City, IA
    I am running an l67 tb with mine, just put a barb on the tb adapter and run a hose IIRC 5/16 from the barb to the pcv nipple on the gen v.
    SMGPFC Two Nipple General
  3. #3 Re: gen v swap
    Waukesha, WI
    ok i dont have the blower in front of me atm, wheres the pcv nipple on it?
    would i be alright spraying nitrous throught the adapter if i have this barb with vacuum hose there too?
    RayRay
    92 Turbo miata
    02 lexus is300
  4. #4 Re: gen v swap
    Charles City, IA
    the nipple is right after the flange for the tb on the back of the blower, you can also punch out the brass plug in the tb and tap in there, you just need to pull air some where post maf.
  5. #5 Re: gen v swap
    Waukesha, WI
    shweet deal, thanks nick
    RayRay
    92 Turbo miata
    02 lexus is300
  1. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  2. swap l67 for l32?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2010, 07:38 PM
  3. L26/l36 swap help
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-11-2010, 02:09 PM
  4. 97 DIC swap ?'s
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2009, 01:35 PM
  5. Almost done with top swap, but in serious need of help
    By sickofsoyo in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2009, 01:26 PM
