Thread: LTFT readings
Results 1 to 11 of 11
  1. #1 LTFT readings
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    Can anyone give me some good ranges my LTFT reading should be at?
    I'm stock except having a short ram with a open cone filter. Running 93 oct gas.
    213k miles
    Have a bit of a stumble just cruising around you can't really see it in the RPM gauge but you can feel the car surging? When it happens.
    Random CEL for a evap but I have a gas leak when I fill up so I know that issue.
    I have replaced the vacuum lines and T.
    MY LTFT was around -14 around 2k RPM 45mph
    I have hit -22 LTFT under boost. I never go into the + side of the LTFT readings.
    I'm new at this so if you need more info let me know.
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  2. #2 Re: LTFT readings
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Ideally you want LTFT's at 0. Plus or minus 3 or so.
  3. #3 Re: LTFT readings
    Nov 2009
    Clinton, Ohio
    So what should I start looking at?
    Thanks for your info.
  4. #4 Re: LTFT readings
    GTX Level Member Juanmiguel's Avatar
    Mexico
    probably a vacuum leak.
  5. #5 Re: LTFT readings
    youre running really rich. in the negatives means the car is trying to pull fuel and right now its maxing out what it is allowed to pull.
    something is wrong.
  6. #6 Re: LTFT readings
    Any DTC's?
  7. #7 Re: LTFT readings
    Nov 2009
    Clinton, Ohio
    No CEL lights but a random for EVAP which is from my gas tank. If i fill it max it leaks.
  8. #8 Re: LTFT readings
    im suprised you haven thrown the rich code yet...
  9. #9 Re: LTFT readings
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    -21 means the evap is purging. You need to fix the evap
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: LTFT readings
    tennessee
    same problem but mine stays at like -12 idle -17 to -21 under boost... looks like im gonna add an evap to my laundry list of parts i need
  11. #11 Re: LTFT readings
    Nov 2009
    Clinton, Ohio
    So what parts of the EVAP system should I start looking at to replace?
  1. Oil pressure readings/misc others 00 GT
    By FordMan77 in forum General Tech Discussion
    Last Post: 05-16-2011, 07:32 AM
  2. what are the proper oil pressure readings
    By Scottydoggs in forum General Tech Discussion
    Last Post: 09-02-2010, 06:11 PM
  3. O2 readings
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 10:44 PM
  4. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
  5. O2 readings
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2008, 02:24 PM
