Thread: Getting 2.5 volts at fuel/sending unit....how come?
Results 1 to 11 of 11
  1. #1 Getting 2.5 volts at fuel/sending unit....how come?
    Apr 2011
    sudbury
    Hey guys i just decided to test how much voltage is coming from the PCM to the sending unit since my gas gauge always says over full on my grand prix 1997 gtp and im reading 2.5 volts with the key on when its saposse to be 12 volts. i figuered out this may be my problem.... but i cant figuer out what device throws the voltage out to the sending unit so i can replace it to fix my issue. anyone know?
    would be greatly helpful.
  2. #2 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Charles City, IA
    gpona.com has a gm service manual with all the wiring diagrams for your car.
    SMGPFC Two Nipple General
  3. #3 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Apr 2011
    sudbury
    no wiring diagram in those service manuals... i checked. unless u can find it for me . thanks 97 gp gtp
  4. #4 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Nov 2010
    Atlanta Ga
    I think that is a 5volt circuit
  5. #5 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Nov 2010
    Atlanta Ga
    9 out of 10 times the level sensor is causing an open circuit. 88 ohms or higher will read a full tank. The float contacts wear causing an open with infinite resistance.
  6. #6 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Nov 2010
    Atlanta Ga
    take the purple wire at the tank and jump it to the black with white wire and the gauge should drop to empty.
  7. #7 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Apr 2011
    sudbury
    Did it and it dint drop to empty stayed up. Even wen the sending unit itself is unpluged it still stays up... Very confusing. Wish there was a wiring diagram on this...
  8. #8 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Apr 2011
    sudbury
    And the fuel sender inside the tank says 43 ohms which is like half tank! Soo theres something not rite
  9. #9 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Nov 2010
    Atlanta Ga
    Quote Originally Posted by guimond47 View Post
    fuel
  10. #10 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Nov 2010
    Atlanta Ga
    send me your email and ill send u the diagram.
  11. #11 Re: Getting 2.5 volts at fuel/sending unit....how come?
    Nov 2010
    Atlanta Ga
    You should have roughly 4.8 volts at purple wire (unplugged and key on)
  1. Oil Sending Unit
    By TeeWX in forum General Tech Discussion
    Last Post: 03-20-2010, 12:31 PM
  2. where to put oil psi sending unit???
    By ERDGT1 in forum General Tech Discussion
    Last Post: 02-01-2010, 09:30 PM
  3. fuel sending unit
    By stanggreg90 in forum General Tech Discussion
    Last Post: 08-01-2009, 06:23 PM
