Thread: Power steering question
Results 1 to 11 of 11
  1. #1 Power steering question
    GT Level Member Whitehispanic's Avatar
    Westborough
    So I found out that my power steering fluid is really dark in color and it should not be like that, I am planning removing all the power Steering fluid and adding new liquid, I personally don't think that is hard to do but I need to make sure I am not missing any steps in the process is there another thread that shows how to do this and what to disconnect so when I do it I don't go into this project blind sided. Or even better step by step would be amazing thanks
    *sig too tall*
  2. #2 Re: Power steering question
    I've heard of a flush machine that some places use, but beyond that..i've never heard of someone changing out their fluid.
    Theoretically you could pull off a line and empty the res. Fill.. work it all in..then drain again.
  3. #3 Re: Power steering question
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    I do that when I'm bored it turns brown so fast, SOMEDAY, somehow I will get it to stay clean.
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  4. #4 Re: Power steering question
    If it works, I don't give it a hard time. Cause I only check the level when the alternator bracket is off. Which means..it hardly ever bothers me...lol
  5. #5 Re: Power steering question
    Westborough
    Well the reason is because my steering is normal, but it makes a whine when I turn the wheels even at idle nothing fills different just the noise. That's why I wanna try this before I have to go changing my power steering pump. I mean what else could be causing the whine?
    *sig too tall*
  6. #6 Re: Power steering question
    I'd pull some out and add some of the PS Lucas goop. If it works miracles in transmissions..maybe they are onto something.
  7. #7 Re: Power steering question
    St. Louis
    I will vouch for the Lucas PS additive. When my rack was getting hard to move and was leaking I added about 2 bottles over the course of about 2 years and it kept it alive and almost completely stopped the leak. Made it quieter too.
    Of course I knew my rack was on borrowed time but had to get as much out as possible before forking over the $$$ for a new one.
  8. #8 Re: Power steering question
    Westborough
    Quote Originally Posted by FordMan77 View Post
    yeah just added some of the lucas power steering fluid and it completely fix the problem did not have to empty the res. Thanks to everyone that help out. i thought it was going to be a lot more complicated.
    *sig too tall*
  9. #9 Re: Power steering question
    Westborough
    It's back nooooooo
    *sig too tall*
  10. #10 Re: Power steering question
    St. Louis
    Can you post a vid of this "whine" you are talking about? I'm not trying to make it hard on you, but these cars all have a bit of whine to them even when they are working correctly. Just seems to be the nature of the beast.
    I would say as long as the PS is still working properly and you aren't leaking any fluid then leave it be.
  11. #11 Re: Power steering question
    Westborough
    I will be posting up a vid a little later today you guys can take a look I am pretty sure it is but u never know.
    *sig too tall*
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. Power steering?
    By apierce1289 in forum General Tech Discussion
    Last Post: 03-11-2011, 04:27 PM
  3. Power steering box
    By j3knoll in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2011, 08:44 PM
  4. power steering question please help
    By mcsddd in forum General Tech Discussion
    Last Post: 12-05-2010, 10:47 PM
  5. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
