Thread: overhaul
Results 1 to 15 of 15
  1. #1 overhaul
    SE Level Member LogicGTP's Avatar
    Oct 2008
    Fremont, CA
    I got the blower and intake out... I live in cali... now that I got those things out what can I do to keep the engine cool, gain hp, better milage, more power... etc while I got everything out. I plan to get the new coupler and clean everything in there but what else can I do?..
    Car is completely stock other than the cai
  2. #2 Re: overhaul
    Waukesha, WI
    port the case
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: overhaul
    Oct 2008
    Fremont, CA
    the blower case? how ?
  4. #4 Re: overhaul
    Waukesha, WI
    the blower case, take the Hbar out, open the V, and smooth the inlet
    RayRay
    92 Turbo miata
    02 lexus is300
  5. #5 Re: overhaul
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  6. #6 Re: overhaul
    Omaha, NE
    A 180* Tstat would help keep a little cooler.
  7. #7 Re: overhaul
    Waukesha, WI
    meh keep the 195
    RayRay
    92 Turbo miata
    02 lexus is300
  8. #8 Re: overhaul
    Omaha, NE
    What is your reasoning for that advice Redline?
  9. #9 Re: overhaul
    because its useless unless youre going for an all out build and just accelerates engine wear as well as decreasing gas mileage since the motor isnt running at optimum temperature. good 'nuff?
  10. #10 Re: overhaul
  11. #11 Re: overhaul
  12. #12 Re: overhaul
    Been doing some more self-edumacating lately.
  13. #13 Re: overhaul
    Waukesha, WI
    we need more of that,
    i run a 180tstat in my gto because with the 455 it like to overheat due to ***** old cooling technology built into those motors, in my gtp i run the 195 and it never goes above that even on 90+ degree days.
    RayRay
    92 Turbo miata
    02 lexus is300
  14. #14 Re: overhaul
    Oct 2008
    Fremont, CA
    So far I removed the old gasket from the blower ( what a pain ) and cleaned really good. Painted it black.
    So, next I will port the blower ( V )
    I'm planing to do a small pulley but I don't know what I can get away without exhaust. This is a low budget overhaul so I wont be planning on running low 12's
    Maybe Some headers but I will need to keep the rest of exhaust. I got rid of the mufflers.
    I notice when I removed the injectors the little plastic ring around them broke off, not the plastic 0-Ring, but a smaller plastic ring. Are those replaceable or do I need new injectors?
    Some vacuum lines broke off to along with the T connectors. I got noise on the steering and some foam on the power steering reservoir.
    Clunk on the right side tire, cv arm? join?
    Much help is needed, I thank any.
  15. #15 Re: overhaul
  1. Overhaul
    By Spartan GL in forum Brakes/Suspension/Chassis
    Last Post: 04-06-2011, 11:49 PM
  2. Suspension overhaul checklist
    By RareGMFan in forum Brakes/Suspension/Chassis
    Last Post: 12-02-2010, 10:58 AM
  3. Quick trans Overhaul
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-11-2009, 08:21 AM
  4. engine bay appearance overhaul...
    Last Post: 08-31-2009, 10:37 PM
