Thread: Running Straight Pipe
Results 1 to 19 of 19
TheAce144 Running Straight Pipe 05-18-2011, 06:42 PM
TheOtherNick Re: Running Straight Pipe 05-18-2011, 06:54 PM
Ricky21 Re: Running Straight Pipe 05-18-2011, 06:57 PM
99prixgt Re: Running Straight Pipe 05-18-2011, 07:00 PM
TheAce144 Re: Running Straight Pipe 05-18-2011, 07:14 PM
gtpsleeper Re: Running Straight Pipe 05-18-2011, 08:02 PM
04boostedindyss Re: Running Straight Pipe 05-18-2011, 08:32 PM
dmahlikGT Re: Running Straight Pipe 05-18-2011, 08:49 PM
TheAce144 Re: Running Straight Pipe 05-18-2011, 11:37 PM
blueguy Re: Running Straight Pipe 05-19-2011, 12:10 AM
AjL227 Re: Running Straight Pipe 05-19-2011, 12:34 AM
blueguy Re: Running Straight Pipe 05-19-2011, 12:35 AM
gtpsleeper Re: Running Straight Pipe 05-19-2011, 02:13 PM
blueguy Re: Running Straight Pipe 05-19-2011, 04:50 PM
gtpsleeper Re: Running Straight Pipe 05-20-2011, 12:10 AM
blueguy Re: Running Straight Pipe 05-20-2011, 02:08 PM
gtpsleeper Re: Running Straight Pipe 05-21-2011, 12:22 PM
blueguy Re: Running Straight Pipe 05-21-2011, 01:55 PM
matt5112 Re: Running Straight Pipe 05-21-2011, 12:51 PM
  1. #1 Running Straight Pipe
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Hello guys, another of those questions with mixed answers.
    I wanted to know if running straight-pipe (cat delete and muffler delete), while keeping the resonator/glasspack, would affect our GTP on performance basis.
    Some say that the Roots Blower on our supercharger create all the backpressure necessary for our engine and therefore everything after manifolds is restriction and for sound-purpose only. Removing mufflers and cat would actually increase horsepower on high Rpm range. A free flowing exhaust is key.
    Others say backpressure is a must on every car and that they should all run with mufflers, even if it means low restrictions one. A car without mufflers would lose low-end torque and the exhaust valves could burn...
    Just wanted to know your opinion, forget about the sound, just performance-wise.
    I personnally removed the mufflers and saw a small difference in low-end torque...however, since headers apparently do the same (Yes, the powerband moves, no real torque is "lost") I guess a pulley drop would fix that.
    Thanks for your time.
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  2. #2 Re: Running Straight Pipe
    Charles City, IA
    Unless you are making 400whp cat back changes will do nothing.
    SMGPFC Two Nipple General
  3. #3 Re: Running Straight Pipe
    Minnesota
    Horrible idea sound like poo. Stock catback wont change power until your above like 300whp or something like that
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  4. #4 Re: Running Straight Pipe
    Jersey
    unless ur turbo'd keep the exhaust
    16' wrx sti- stock
  5. #5 Re: Running Straight Pipe
    Dec 2010
    Montreal, Canada
    It actually sounds really good with the glasspack, except when the engine is cold. I'm planning on getting some stainless mufflers to reduce drone on highway.
  6. #6 Re: Running Straight Pipe
    just get mufflers that are non restrictive if your worried about it... something that is just straight through wont have any restriction and will help in sound...
  7. #7 Re: Running Straight Pipe
    GT Level Member 04boostedindyss's Avatar
    May 2011
    boynton beach florida
    headers stock mufflers no cat and no res sounds pretty decent on my car, pretty much zero drone and barely any rasp..
    E85, Gen V, Xp, Supporting mods, crap tune!
  8. #8 Re: Running Straight Pipe
    Florida
    Hey OP i have cat and muffler delete with a glasspack as well although im a GT.It sounds excellent at idle, beastly when i rev and very good when i go WOT...buttt cruisin blows sadly.too much drone especially at highway speeds.And yea once i removed my mufflers torque does seem to be taken away a lil.mufflers to come
  9. #9 Re: Running Straight Pipe
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by dmahlikGT View Post
    Same for me, drone is not so bad though!
  10. #10 Re: Running Straight Pipe
    This thread...
    makes me...want to do this.
  11. #11 Re: Running Straight Pipe
    GTP Level Member AjL227's Avatar
    IL
    Don't do it, keep your stock exhaust. I regret not keeping mine, however I will be adding a 32" triple chambered Magnaflow resonator in replacement of my zzp exhaust's 12" single chambered Magnaflow. I will keep my fingers crossed this will stealth my car down quite a bit.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  12. #12 Re: Running Straight Pipe
    It will.
    People have complained plenty about ZZP's catback being droney as ****
  13. #13 Re: Running Straight Pipe
    = Nick
  14. #14 Re: Running Straight Pipe
    Says the guy with turbo whistlers on his exhaust tips and thought they cool...
    I GOT YOU BRO
    ha...keep going I have pictures
  15. #15 Re: Running Straight Pipe
    I GOT YOU BRO
    your never gonna let that go are you...
  16. #16 Re: Running Straight Pipe
    Quote Originally Posted by gtpsleeper View Post
    Oh...and that certain race
    Care for a rematch?
  17. #17 Re: Running Straight Pipe
    Care for a rematch?
    very much want a rematch my friend!
  18. #18 Re: Running Straight Pipe
    You gots mah digits foo
  19. #19 Re: Running Straight Pipe
    Omg...............................
    Exhaust should be sized for the power level you're at.
    Mandrel is always better than crush bent.
  1. Straight Hwy MPGs
    By TLSheff in forum Off Topic Discussion
    Last Post: 02-16-2011, 10:37 PM
  2. RWD, 6-spd, Straight Six...
    By blueguy in forum Off Topic Discussion
    Last Post: 07-10-2010, 08:00 PM
  3. noob to car audio set me straight
    By 02blackgpgt in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 11:04 PM
  4. Supercharger - So let me get this straight...
    By RAZOR Z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2009, 11:05 PM
  5. Straight Pipes on GTP?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2008, 08:12 PM
