so im planning on TOP SWAPPING my engine, so higher compression than the l67 and all that good stuff. if i go with a intake, sd headers, rockers, 180 t stat, 10.3mm wires, colder plugs, and a tune, what do you think the smallest pulley i can run is without knock? and what do you think would need to be done to get to a 3.4 cause im guessing that wouldnt quite get me there?
suggestions advice and wise words of wisdom are welcomed
