Thread: looking into xp cam, have a few questions
Results 21 to 40 of 43
  1. #1 Re: looking into xp cam, have a few questions
    GT Level Member 04boostedindyss's Avatar
    May 2011
    boynton beach florida
    That XP vid says 600 RPM, a stock cam could sound lopey at 600rpm idle. A lot has to do with the rpm. If you bring it up 100rpm, things smooth out.
    I use 1/4" NPT brass plugs with recessed heads with a little pipe sealant on them. Same goop as you should use for LIM bolts.
    If you want to go further you open up the end cap on the LIM that is under the TB and realize why we have poor flow from rear head to front. Then you open that up a bit. By doing this additional step, I kept #4 from running hotter than the other cylinders. Typically the middles run hotter and #4 being in the back, runs the hottest of all.
    hmm very interesting, thanks for that info..I'm guessing I can get those brass plugs at home depot?..and I know the rpm plays a big roll, he has a 900 rpm idle vid to with the xp.
    900 rpm xp
    YouTube - GTP, XP cam idle vid, 900RPM.
    Still think the s1x sounds better and has more lope?
    Here is the ultimate question I'd like to get some feed back on...which cam should I buy over the other and why?.. id like to be in the 12s and have good topend with out having to rev past 6400 and use the same valvetrain components listed previously..
    E85, Gen V, Xp, Supporting mods, crap tune!
  2. #2 Re: looking into xp cam, have a few questions
    GenV...that's quite a big step if you were both on 3.4"s...your comparing apples to oranges guy. A 3.4" on a GenV...is like a 3.2" on your car.
  3. #3 Re: looking into xp cam, have a few questions
    May 2011
    Believe me I know that's why I posted saying he has the advantage, I may be new on here but by no means am I new to the l67/l32... I'm just looking for a little edge to try and even out my gen 3 to his gen v lol....before the cam went in his car and even before I had rockers we would be pretty much dead even....I have a bunch of Vids if interested, and both cars where running kr free...I'm just so impressed with his vs cam, I could only imagine a xp or s1x!.
  4. #4 Re: looking into xp cam, have a few questions
    XP vs S1X, you will find they are nearly the same. One creates a smidge and I mean barely a difference at the low end and the other is a smidge better at the top end. You'd never really notice it in a race though.
    On the idling.. Yeah, I'm positive. I've installed at least 3-4 of each and owned an S1X for 4+ years.
  5. #5 Re: looking into xp cam, have a few questions
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Quote Originally Posted by 04boostedindyss View Post
    Id like to see the vids. And im glad this thread was made because i will be going with the xp cam sometime this summer and getting rid of my rockers.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  6. #6 Re: looking into xp cam, have a few questions
    May 2011
    Hhmm so I should go s1x over xp ?...and if so still use the same parts as listed earlier?
  7. #7 Re: looking into xp cam, have a few questions
    Banned
    CT
    You can't go wrong with either, I have an XP and I love it. The reason I chose it over the S1x is because the overlap is a half degree more and comes with a little bit more lift.
  8. #8 Re: looking into xp cam, have a few questions
    Quote Originally Posted by SnowFlake View Post
    You can't go wrong with either, I have an XP and I love it. The reason I chose it over the S1x is because I got the best deal on it.
    There ya go.
  9. #9 Re: looking into xp cam, have a few questions
    The XP utilizes a little more top end which these cars lack...which is why I went with it over the S1X.
  10. #10 Re: looking into xp cam, have a few questions
    May 2011
    Awesome, guess I made up my mind...anyone know if I can get a discount on one LOL..
    I'm ordering a Racetronix fuel pump rewire tonight as well as a new fuel filter then ill have all my parts needed for e85...should I just go e85 before the cam or wait till after?
  11. #11 Re: looking into xp cam, have a few questions
    going for a pump or just a rewire?
    Might want to think about a treperformance.com high flow pump. I've been using a couple for years. If you are aiming for save a buck.
  12. #12 Re: looking into xp cam, have a few questions
    May 2011
    Just a rewire for now ..but maybe a pump eventually. Injectors and rewire new fuel filter and tune should be good for a basic e85 once I have a 2.6 pully and intercooler it will be time for the new pump
  13. #13 Re: looking into xp cam, have a few questions
    May 2011
    Hey now bill is awesome for providing good info and going through all the trouble, but you may be right
  14. #14 Re: looking into xp cam, have a few questions
    May 2011
    Awesome. I'll post Vids later once I get home and can use my laptop
  15. #15 Re: looking into xp cam, have a few questions
    I liked my XP...but it wasn't big enough...so I went stupid
    YouTube - XP Cam Start-Up
  16. #16 Re: looking into xp cam, have a few questions
    May 2011
    Well I won't be doing any head work for a while, and xp seems to be the best for stock heads....what did you go with xpz?
  17. #17 Re: looking into xp cam, have a few questions
    The Thrasher Engineered Performance Race Cam...it's pretty beefy.
    YouTube - Big Cam GTP Idle & Rev
  18. #18 Re: looking into xp cam, have a few questions
    after being in and around, now, three cars with the TEP (including my own) it isn't big enough. i'd need something bigger if i did it again.
  19. #19 Re: looking into xp cam, have a few questions
    Jersey
    my car idles at 900 and its still loopy. In drive with the brake petal depressed you wont notice it too much but when in neutral or park, it sounds a little wild. 4,500-6,000 and up is where this cam really shines. I went with xp after i went for a ride in an xp car, got rid of the rockers and didn't look back.
    If you want 6400 rpm shift points, your going to need 1.6 rollers
    16' wrx sti- stock
  20. #20 Re: looking into xp cam, have a few questions
    Chris.. you know how little time I have. I'm only trying to help out. There's a lot of guys that don't realize parts are much cheaper when you aren't paying the overhead and shipping from a 3800 vendor. Can't fault those guys for making money, but heck..the pricing differences on some stuff is ridiculous.
  1. new here with questions
    By wide open 97 in forum Visual/Body Modifications
    Last Post: 12-25-2010, 04:07 PM
  2. NIC cam questions
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 02:20 AM
  3. Few Questions :)
    By GrandPrixSE in forum General Tech Discussion
    Last Post: 06-06-2010, 08:20 AM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. Got some questions about my 97 GP SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 10-26-2009, 12:42 PM
