Thread: vin on motor??
Results 1 to 9 of 9
  1. #1 vin on motor??
    GT Level Member m17davis's Avatar
    Orland Park, IL
    hey guys. i was wondering if there was a vin number anywhere on my motor? i bought a motor from a junk yard because i was going to build the original motor up and fix coolant and oil leaks. when i get the new motor in i realize that the second motor is also leaking. so i was going to try to give them my original motor and get the money back, im kinda desperate for money now.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: vin on motor??
    I live here. TLSheff's Avatar
    Not that I recall seeing when I put the engine back in mine, but I really wasn't looking for it either. Usually its a plate of some sort if it has one on it.
  3. #3 Re: vin on motor??
    Omaha, NE
    No vin, just the engine code is listed.
  4. #4 Re: vin on motor??
    I'm sure they're NOT going to give you money back for it.
    Probably exchange only. If not, they'll give you credit.
  5. #5 Re: vin on motor??
    SWPA
    I guarantee they have the one they sold you marked.
    You wont get money back unless you give them the one they sold you, and don't have another one. If it was a pick a part yard, you buy it, its yours. No returns.
  6. #6 Re: vin on motor??
    Orland Park, IL
    There is a 101 day money back guarentee.
  7. #7 Re: vin on motor??
    SWPA
    You have to read the fine print on those "money back guarantee's"
  8. #8 Re: vin on motor??
    Typically they put a heat tag on them. That way if you try and bring it back w/o the tag, they know you overheated it.
  9. #9 Re: vin on motor??
    St. Louis
    What is it leaking exactly? If it's coolant or oil then those are a simple fix. These motors are not "dry" motors to begin with. Buying a used motor from a jy and expecting it to have no leaks is like going out in the rain and expecting to not get wet.
    Change the LIM gaskets, oil pan and valve covers and I'd bet all your leaks will stop for now.
  1. Motor Done!!!
    By Sl33p3rGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2011, 11:15 AM
  2. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  3. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  4. The motor out of the Z26
    By Zach3800 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2008, 01:12 AM
