Thread: Hissing noise?
Results 1 to 20 of 23
  1. #1 Hissing noise?
    Donating Users LuckyBambu's Avatar
    Feb 2010
    Chicago, IL
    Have a hissing noise coming from the sc area.
    YouTube - May 7, 2011 9:32 AM
    Help please? Bad pulley? Vac line? Dare I ask if it's the supercharger?
    2000 Pontiac Grand Prix GTP Stock
    Coming Soon: Headers, Intake, Tune, Pulley Drop, Thermostat, Spark Plugs, Ported Supercharger, Ported Throttle Body, Coolant Switch (Green Stuff ), Headlights/Taillights, Speakers, HUD Fix, LED Interior
  2. #2 Re: Hissing noise?
    sounds like a vac leak, look under the s/c snout and check the T of vac hoses, it may have popped of or broke.
  3. #3 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    I did look... how tight should they be?
  4. #4 Re: Hissing noise?
    snug enough not to leak, follow those lines around the engine, something is off its loud, or spray some carb cleaner around the engine till you hear the idle jump when sprayed , then check that area for the vac leak source.
  5. #5 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    Seems like it may be the t before the one under the supercharger snout... It's pretty loose. I'll pick up some carb cleaner this week though and play with it... So long as it's not the supercharger hah
  6. #6 Re: Hissing noise?
    GT Level Member Tea Time's Avatar
    New Brunswick
    if u think its that t, then pull it off the lim and the black lines out of both sides VERY CAREFULLY and check for cracking...its just a rubber t....flex it a bit and u'll see cracks if any.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  7. #7 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    Welp I guess I'll get around to it tomorrow. Need to get back to Chicago from Milwaukee then buy some carb cleaner and go wild
  8. #8 Re: Hissing noise?
    Jul 2008
    sumter,south carolina
    sounds like a pulley to me... take off SC belt and see if it goes away. if it does, more than likely its a pulley that runs on SC belt.. im thiking idler pulley.
    02 GTP with mods 05 GP for DD
  9. #9 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    Thanks... Will look into that as well
  10. #10 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    It seems like one of the pulleys is bad, making some odd noise, though...
    now I have an issue where I hit about half boost (4 legos) and the car will start shaking. So I guess I have to check the vacuum and plugs now...
  11. #11 Re: Hissing noise?
    Vacuum leak will run you lean and that'll cause misfires or blow your engine from detonation.
  12. #12 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    Doesn't happen when I'm going slower than 50-55MPH it seems... I soaked the vac lines in carb cleaner and no increase in idle and no obvious leaks.
    Spark plugs maybe? Something like that?
  13. #13 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    Plugs fixed the rumbling at 4 legos of boost. Did Autolite plugs and wires... $85 later it's running nicely.
    Just have to fix that hissing still... sure it's probably a pulley. Will replace that this weekend.
  14. #14 Re: Hissing noise?
    I live here. TLSheff's Avatar
    Be careful, I saw a video on Youtube the otherday... Woman complained that there was a hissing sound comming from her engine... it was a 6ft snake
    Your prolly right, its prolly a pulley, don't put it off tho! Check it NOW!!! If the pulleys bearings going out, and if it locks up the plastic will just melt itself off when the tq from the engine keeps rotating it and you will most likely lose your belt with it. I was fortunate when it happened to me, it tossed the belt onto the supercharger and there it stayed, most people lose the pulley and the belt tho
    just fyi
  15. #15 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    Do you think it's probably those tensioner pulleys? Those are the only ones that seem to have the bearings in them.
    Was going to replace them this weekend.
    Thanks!
  16. #16 Re: Hissing noise?
    The one I spun off was #9, just a regular Idler pulley for the supercharger. I didn't even notice until I went to get on the Hwy and had no power, no boost :P I pulled over and the supercharger belt was just sitting on the supercharger and there was a shiny little shaft with the shiny metal bearing on it, no black pulley anywhere... just melted it off at the base. Never found the pulley either :P They all have bearings so best would be to pull both belts, check the play on the SC for coupler and spin all the pulleys for rough spots
  17. #17 Re: Hissing noise?
    #3, #8, and #9 are plastic from the factory...get the metal replacements and never look back.
  18. #18 Re: Hissing noise?
    smooth flow pulley system time?
  19. #19 Re: Hissing noise?
    Feb 2010
    Chicago, IL
    I was going to get metal pulleys, seems like plastic is kind of ****e. Especially with how much heat is there anyway.
    Smooth flow?
  20. #20 Re: Hissing noise?
  1. weird hissing in dash...
    By 2000GTP in forum General Tech Discussion
    Last Post: 06-19-2012, 03:09 PM
  2. Hissing noise, is it the fuel pump?
    By Frank217 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2012, 06:58 AM
  3. Hissing Noise On A 1999 Pontiac Grand Prix
    By GrandPrixChic in forum General Tech Discussion
    Last Post: 12-24-2010, 02:00 AM
  4. Hissing after turning engine off
    By yekimmrt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2010, 06:19 AM
  5. Cold Start Hissing
    By SuperSport in forum General Tech Discussion
    Last Post: 07-24-2009, 12:56 PM
