Thread: Supercharger gasket
Results 1 to 18 of 18
  1. #1 Supercharger gasket
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    Ok so I am planning on replacing my intake manifold gaskets possibly this weekend and the advanced auto down the road sells the upgraded aluminum gaskets and all intake orings for cheaper than to have it shipped from anywhere else. But, they don't carry the supercharger gasket. My question is Re you able to pull the intake and the supercharger off at the same time so I don't have to wait for shipping for the gasket?
  2. #2 Re: Supercharger gasket
    its called the upper plenum gasket
  3. #3 Re: Supercharger gasket
    Dec 2010
    Lawrenceville, GA
    Oh... Thx alot
  4. #4 Re: Supercharger gasket
    Grand Island, Nebraska
    Yes. And I would also dowse the LIM and top of the gasket with red RTV to prevent leaks.
  5. #5 Re: Supercharger gasket
    Dec 2010
    Lawrenceville, GA
    Yeah that's what I plan to do! But thx for looking out ;-) oh and I forgot how to relieve fuel pressure can anyone enlightenment me? Lol
  6. #6 Re: Supercharger gasket
    Quote Originally Posted by JoRoW99 View Post
    no?
    just the corners.
    as per the instructions.
    if your LIM is pitted, you need a new LIM or it needs to be machined.
    RTV isn't the solution.
  7. #7 Re: Supercharger gasket
    Dec 2010
    Lawrenceville, GA
    Oh and my other question besides the fuel pressure is what does the Lim and the s/c need to be torque down to?
  8. #8 Re: Supercharger gasket
    no?
    just the corners.
    I meant on top of the LIM, like on both sides of the SC gasket. But you are correct only put RTV in the corners for the LIM gasket.
  9. #9 Re: Supercharger gasket
    Dec 2010
    Lawrenceville, GA
    ok so basicly i shouldnt torque the LIM? or is in/lbs correct? or should i just get it nice and hand tight?
  10. #10 Re: Supercharger gasket
    Push in the schrader valve with a screwdriver and stand back lol
  11. #11 Re: Supercharger gasket
    Dec 2010
    Lawrenceville, GA
    Lol yeah I did that when I pulled my fuel rail off to swap injectors >. < any safer way lol
  12. #12 Re: Supercharger gasket
    17 ft lbs or so.
    not much really.
  13. #13 Re: Supercharger gasket
    Portland Oregon
    To relieve fuel pressure, start the car, pull the fuel pump relay, let car die. Problem solved
  14. #14 Re: Supercharger gasket
    Dec 2010
    Lawrenceville, GA
    17 for both the s/c and Lim? I saw they had 132in/lbs for the intake this correct?
  15. #15 Re: Supercharger gasket
    probably.
    tried torquing LIM bolts once.
    broke the bolt.
    never torqued another one since.
  16. #16 Re: Supercharger gasket
    You should torque it.
    I didn't have good luck with that when i tried it.
    i torque them similar to an oil filter.
    till it meets, then 1/4 of a turn (instead of three quarters like the oil filter.)
  17. #17 Re: Supercharger gasket
    LIM isn't anymore than 12 ft.lbs. Even though I've never really TQ'd it correctly. Blower isn't much more either...which I've never TQ'd either...and never did it in any certain order.
    Only thing I am wary about...because they break EASY...are the fuel rail nuts...barely snug them down...and TB nuts...because said studs can break on both very easy.
  18. #18 Re: Supercharger gasket
    Wichita, KS
    Supercharger gets torqued to 17 ft. lbs.
    LIM:
    3.8 VIN K = 89 in. lbs.
    3.8 VIN 1 = 11 ft. lbs.
    (roughly both get 11 ft. lbs.)
    BOTH supercharger and LIM have to be torqued in sequence, starting in the middle, and working your way out to the ends in a "X" pattern.
    Mainly the 4 upper most LIM bolts get thread sealer because they enter the heads valve train, I normally coat ALL the LIM bolts with thread sealer when I reassemble, cause that's how they came out.
    GenIII M90s, don't forget the coolant o-rings with the gasket.
    GenV's...they are built into the gasket so no worries.
    ~F~
  1. Supercharger Gasket
    By Spazztic2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-17-2010, 02:47 PM
  2. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  3. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
