Thread: Coolant leak Please help
Results 1 to 10 of 10
  1. #1 Coolant leak Please help
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    Im losing my mind, i have an L67 About to buy a l32 or sell the car if i cant fix this.
    I have a coolant leak (light smoke out of the exhaust) i keep getting coolant inside of the Intake manifold, and then its burning in the chamber.
    I have Done so far, replaced the head gaskets, ZZP aluminum intake gaskets, Blocked the Supercharger coolant ports AND tried a SECOND intake manifold.
    That's Typically the only thing that Stops a coolant leak Right????
    Is it possible i have a cracked block or Head? And how the hell could that happen????
    Also there is NO coolant in my oil just in the intake.
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  2. #2 Re: Coolant leak Please help
    Houston
    Coolant Elbows?
  3. #3 Re: Coolant leak Please help
    FLINT/michigan
    Brand new
    but that WOULDNT cause white sweet smelling smoke out of the exhaust
  4. #4 Re: Coolant leak Please help
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Pop off the blower, Pressurize the system and see where it leaks.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: Coolant leak Please help
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I bought that reusable gasket with the yellow o rings and havnt had a problem with it and i just had to replace my m90 today?
  6. #6 Re: Coolant leak Please help
    FLINT/michigan
    How would i go by pressurizing the blower
  7. #7 Re: Coolant leak Please help
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Have you checked for a blown head gasket? Check cylinder compression on each cylinder.
    Lambokit to be built!!!!!
  8. #8 Re: Coolant leak Please help
    Hagerstown,Md
    No Im saying take the blower off and look into the intake and pressureize the coolant system and see where its leaking from. Just make sure the coolant passages are blocked off good to the TB.
  9. #9 Re: Coolant leak Please help
    FLINT/michigan
    Quote Originally Posted by lambokit View Post
    Brand new felpro headgaskets/ bolts, zzp aluminum intake gaskets, And blocked off supercharger Coolant ports.
    Quote Originally Posted by 01gpgt01 View Post
    Right i got what you meant, but im tired and said the wrong thing lol
    Whats the best place to blow air through?
  10. #10 Re: Coolant leak Please help
    Hagerstown,Md
    Radiator Pressure Tester Kit Through the Cap. DOnt go over 16psi. Id imagine you could rent one. Heres a cheaper one aswell. http://www.google.com/products/catal...ed=0CCkQ8wIwAA#
  1. Coolant Leak
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 10:06 AM
  2. Coolant leak help!!!
    By Sl33p3rGt in forum General Tech Discussion
    Last Post: 12-21-2010, 03:58 PM
  3. Coolant leak?
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 01:59 PM
  4. Coolant Leak
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 01:16 AM
  5. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
