Thread: selliott turbo gp
Page 11 of 40 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 785
  1. #201 Re: Up and running......again
    I break stuff selliott's Avatar
    Kansas City
    I knew about that one I wasn't sure if there was supposed to be one on the reservoir as well I'm guessing the sensor is bad.
  2. #202 Re: Up and running......again
    Kansas City
    Just a little update, the weird rpm bounce (acting like its hitting the rev limiter) was due to the truboost vacuum lines being run wrong. The numb nuts i had help me put it in had it all jacked up. Now that its fixed it runs beautifully. Thank you gmr and swiggles for your help
  3. #203 Re: Up and running......again
    Bastard Reptile's Avatar
    Kansas City, MO
    Good thing I just plugged in the knock sensor for ya.
  4. #204 Re: Up and running......again
    Kansas City
    Yes sir, I'm glad we found the extention for it too.
  5. #205 Re: Up and running......again
    Kansas City
    Longer brake lines and oil pressure kit should be here early this week so that's a plus.
  6. #206 Re: Up and running......again
    Kansas City
    I was doing the brakes on the Acura so I decided to see what the gp would look like with 19s, I was too lazy to actually put them on tho lol.
  7. #207 Re: Up and running......again
    Antioch, IL
    thats huge
    2009 Challenger SRT8
    Expert at being gay.
  8. #208 Re: Up and running......again
    Kansas City
    I agree, but bios old gp had 19s and it looked great. I think a lower profile tire would look a lot better On the gp, but i have traction issues on my 17s so lack of sidewall would be a big issue.
  9. #209 Re: Up and running......again
    Kansas City
    I got the new double din mocked up today
  10. #210 Re: Up and running......again
    Kansas City
    Little bit of tire spin
  11. #211 Re: traction....what's that?
    Antioch, IL
    should I just sell my turbo slow car now or later
  12. #212 Re: traction....what's that?
    Kansas City
    "Spinning aint winning"
  13. #213 Re: traction....what's that?
    Antioch, IL
    it is when your still faster than the other car
  14. #214 Re: traction....what's that?
    Kansas City
    Its quick but im sure there is still alot faster on here
  15. #215 Re: selliott turbo gp
    Kansas City
    Now that's it's warming up outside my trans temps are higher than I would like even with my trans cooler, upper 220s at highway speed.....so I'm gonna have to fix that
  16. #216 Re: selliott turbo gp
    thats a bit higher than normal with a trans cooler. when mine was turbo'd it'd be around 185-190 after a few WOT pulls. normally cruising its around 180. both fan on high speed mode.
  17. #217 Re: selliott turbo gp
    220*...that...meltage
  18. #218 Re: selliott turbo gp
    Kansas City
    Nick from what reptile was saying I think you and I have the same cooler from dave, I'm not sure why my temps are so high but I'm sure it's my fault whatever the problem is. And yeah fst I'd expect 160-180 mark but just not happening. Reptile thinks my 3k converter may play a part in the equation
  19. #219 Re: selliott turbo gp
    GTP Level Member
    Jan 2015
    Lincoln, NE
    does it shift funny, hard? gear ratio the same as your stock ratio?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  20. #220 Re: selliott turbo gp
    Dave seems to think the converter plays a decent part in it too.
    Did you bypass the radiator during install?
    And where did you mount the cooler itself?
    Mine is literally right behind in the grille in front of everything.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. This build
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2011, 09:19 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
