Thread: LIM cracked?
Results 1 to 20 of 20
  1. #1 LIM cracked?
    Dec 2010
    Lancaster, OH
    I had leaking intake gaskets when I bought the car as he said it was overheating and that he had replaced the water pump but that it didn't fix it. I replaced the radiator, installed a new thermostat (since it didn't have one) new radiator hoses, GM intake gaskets and a new SC gasket along with new valve cover gaskets. All of the surfaces were cleaned properly and torqued to spec. But... while trying to purge the air out of the system, I keep getting a surge of air in the coolant. If I rev up the engine I can see it forcing the coolant into the overflow bottle. Not to mention I still don't have any heat. Also I get fluid in the pocket in the LIM closest to the thermostat. I inspected the LIM when it was off but I'm starting to think that it has a crack and the forced induction it forcing air into the coolant. That or the gaskets aren't sealing it off. Any one have any ideas? This thing is killing me! I just want to get it running properly so I can sell it.
  2. #2 Re: LIM cracked?
    Charles City, IA
    3.8 or 3.1?
    SMGPFC Two Nipple General
  3. #3 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    1997 GTP w/ bone stock L67. The SC has been rebuilt by the previous owner but not ported.
  4. #4 Re: LIM cracked?
    Charles City, IA
    Do a cylinder leak down test
  5. #5 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    I've got a cylinder pressure gauge. What else do I need? I should also add that it doesn't leak coolant into the oil, and it doesn't burn coolant either. It just builds serious pressure in the cooling system.
  6. #6 Re: LIM cracked?
    Charles City, IA
    Check each cylinder sounds like you have a cracked head or a blown head gasket.
  7. #7 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    Oh boy. I was hoping for anything but that.
  8. #8 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    But I am still confused as to how a head gasket would allow fluid to leak out on top of the LIM. It appears to be either coming out one of the bolts or through a hair line crack. Because the water bubbles like a leaky tire but I can't tell exactly where they are coming from.
  9. #9 Re: LIM cracked?
    It's about a 99% chance you don't have a bad head gasket. Although you metnioned it being overheated and it's possible because it's a gasket.
    First thing, get a new radiator cap. If you can see coolant going into and out of the overflow w/o the car being up to temp, then your cap is not longer functioning properly.
  10. #10 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    I've tried a different cap on the radiator. With the hood popped and looking at the overflow bottle, if I rev up the engine you can see a surge of water come rushing into the overflow bottle. It's like turning on a faucet.
  11. #11 Re: LIM cracked?
    Hmmm that's usually a sign of a bad cap. Ok,, I gotta think further on this one.
  12. #12 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    Ponder all you want Bill! That's the nice thing about having two of these cars side by side in the driveway. I can steal parts from one to test small issues on the other. I might add that when I bought the car, there was evidence (orange residue) all over the overflow bottle by the intake and where it was coming out the radiator cap. The original overflow bottle's diptube was down in the tank so it couldn't recover coolant. I installed the later version on the strut mount so I could install a CAI if I wanted to so it looks to have had this problem a while.
  13. #13 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    Ordered all the parts to do change the head gaskets this weekend. I just hope it stops raining by then.
  14. #14 Re: LIM cracked?
    If I were you...I'd do a lot more testing before going in for that much work .That's how infrequently these gaskets fail. Even when being overheated.
    Not that I'd know.. second day I had a 95 Bonne I did about 80 up the highway not realizing a heater hose had popped. It got warm...very very warm Not an issue.
  15. #15 Re: LIM cracked?
    SE Level Member Shang TI's Avatar
    Austin TX
    My car overheated one time because of my lim gasket and I cracked a head lol, that was fun. Replace lim and head gaskets and see what happens just dont reuse the head bolts
  16. #16 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    I bought ARP bolts for the rockers when I changed the lifters so I only need new head bolts. The only thing that seems like it will suck are the exhaust manifolds. Any advice on getting them off the heads?
  17. #17 Re: LIM cracked?
    They are actually pretty easy. On the job, I'd say pull the front manifold, then unbolt the rear from teh egr and the rear head. Then pull your exhaust back with a ratchet strap. All you need is about an inch to inch and a half. I'd even leave the crossover on the rear manifold.
    Did it that way when I swapped heads. Worked great.
  18. #18 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    OK. Update time. I took it all apart down to the block. Both head gaskets appeared to be fine but the brand new GM intake gasket had a tear in one of the water ports. The car now has the following "NEW" parts...
    radiator, water pump, 180 Deg. thermostat, radiator hoses, coolant elbow, head gaskets, intake gaskets, SC gasket w/ o-rings, radiator cap and updated coolant bottle. I inspected everything while it was off looking for cracks of any kind and found nothing but that intake gasket. Also what is the best way to get ALL of the air out of the system? It ran for like 5 minutes, the temp gauge never moved, there was NO heat coming from the vents and the bleeder screw on the thermostat was open and pouring water out and I wasn't getting any air. It acts like it's not able to circulate water or push the air to the top. Do I need to take the heater core hoses off and pre-fill them with coolant? After it cooled down for a few minutes, I opened the radiator cap slowly and a huge rush of coolant was forced into the overflow bottle from the built up pressure. I imagine, it's trapped air getting hot and expanding therefore building pressure with no where to go. Also while the car was torn down I forced clean water through the block and heater core and they flow free. Any help would be great. I'm starting to hate these damn things.
  19. #19 Re: LIM cracked?
    to bleed the system, with the car cold, open rad cap, start car, idle engine till the fans come on,(make sure the a/c is off.) that way you know the t-stat opened up, top off coolant, open the bleeder, leave open till coolant comes out in a stream, shut bleeder, top off rad, cap back on rad your done.
    its going to take longer than 5 minutes to get any heat out of the engine, idle it longer. it may take up to 15 minutes, just idling.
    fill reservoir bottle to cold line.
  20. #20 Re: LIM cracked?
    Dec 2010
    Lancaster, OH
    Thanks for the help Scottydoggs! I got all of the air out that way and it is finally running cool. Now on to the next issue with this thing.
  1. Had a boo boo and now my dash is cracked..
    By hondo in forum Visual/Body Modifications
    Last Post: 03-12-2011, 12:12 PM
  2. Cracked Flexplate Symptoms???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-24-2010, 06:22 PM
  3. Cracked wheel
    By 99whitebeast in forum Tires & Wheels
    Last Post: 03-15-2010, 10:32 AM
  4. Cracked Radiator
    By the955iman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 11:31 PM
  5. Cracked windshield
    By wayne1981 in forum Visual/Body Modifications
    Last Post: 12-16-2007, 10:42 AM
