Thread: cam help
Results 1 to 20 of 21
  1. #1 cam help
    SE Level Member shawnrandolph's Avatar
    michigan
    Hey guys I recently got a 2000 gtp. It was a demos car exept for the cam. I've put headers a built tranny 3.4" pulled and a warm air intake. Open cone. I need help finding outwhat cam I have. I plan on using a dial indicater soon for lift. All I know is at idle I pull 11 in of vacuum and with the 3.4 pulley I get 9 lbsof boost. The idle is a lil lopey butnot horrible.
    Thanks guys. Sorry this was typed on my phone
    ported polished gen v, Ahcohol Injection Systems comp. trunk mount stg. 2 meth, 42lb 3" pulley headers built trans, xp hot cam
    blower port and outside polish pm me
  2. #2 Re: cam help
    knowing the car is on stock heads, it's more than likely an XP, S1X, or a VS. the most common out of those being an XP, so it'll probably be that.
  3. #3 Re: cam help
    michigan
    thanks for the replies but the xp is a lopey cam at idle right?
  4. #4 Re: cam help
  5. #5 Re: cam help
    michigan
    can anyone with a xp cam chime in with vacuum in/hg. And does 9 psi sound right with the 3.4 pulle
  6. #6 Re: cam help
    11" sounds pretty weak for an XP.
    Even an XPZ is supposed to pull 14.
    vac leak?
  7. #7 Re: cam help
    Maybe it isn't even cammed.
  8. #8 Re: cam help
    vac leak that big would result in misfire.
    thus "lope"?
  9. #9 Re: cam help
    michigan
    Ive replaced all the lines that looks rough and sprayed the entire engine bay with carb choke cleaner looking for a leak and found none. Now 11-12 is on my boost guage which is a cheap one. The aeroforce says im at like 14. Not 100% but it was not what the boost guage says
    I know the boost guage needs a upgrade for sure. Just worring about everything else right now for dyno day
  10. #10 Re: cam help
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I have a VS cam with 3.25 pulley and the powrtuner says I'm making 6 lbs of boost and the sunpro gauge said 11. I'm not sure which one to believe. 6 sounds too low.
    Stick to something more scientific, how many bars do you get in your DIC? hahaha.
    here's a video of my car at idle:
    YouTube - GTP VS cam idle and rev
  11. #11 Re: cam help
    MO
    Easiest way to know which cam you're running: Put in one yourself
    <brandonl2000> LMAO D!!
  12. #12 Re: cam help
    michigan
    thats why i want to know which one i have so I dont put the same cam in myself. I want to do a xp hot cam.
    Yesturday my interceptor says im at 13.8-14.7in/hg at idle. It flucuates with the lopey idle. Im uploading a video to photobucket when i first put the headers on so its idleing with open headers. Now i never let the car warm up fully in the video cuz towards the end of the video i realized i never put my egr back on so thats the sound that sounds like a rod knock lol
  13. #13 Re: cam help
    even if it is an S1x or a VS, it will still perform just as well as an XP. why would you want to change it?
  14. #14 Re: cam help
    If you didn't have the EGR on...and you had open headers of course its gonna sound lopey...it has an exhaust leak before the o2 and was probably throwing off your fuel trims.
  15. #15 Re: cam help
    michigan
    The egr was fixed 5 minutes right after the video so i have no leaks.
    This weekend im going to just put a dial indicator on the push rod and the rocker arms and crank it over by hand. This should answer all my questions and should give me my lift pretty accurate.
    Thanks for helping anyways guys
    Ill post up my numbers when i get them. The onl thing is i wont be able to do duration but the lift numbers alone should give me a idea.
  16. #16 Re: cam help
    Boost gauge is probably reading foot lbs. Having a Bonne with the ft lb gauge, 10-11 was very normal vacuum reading.
    On an hg gauge though..you'll see 14-17 vacuum.
  17. #17 Re: cam help
    michigan
    okay guys i took the cam out last weekend while i was doing all the other mods. . it measured out to be the xp cam and i have confirmed it with zoomer also. Now that i figured that out i am curious on my springs. Looking down the ports with the intake off I do see casting marks so im not thinking i have ported heads which is fine. for now. But i need to know about the springs. To me they look like coiled up piano wire, Just big wire. But what about the diameter of the springs. Can people chime in on the actual wire diameter for stock and 90# and 105#. I assume that the wire is thicker with harder springs correct?
  18. #18 Re: cam help
    Post a picture.. Geez...lol
    Yellow is LS6
  19. #19 Re: cam help
    michigan
    yes and when i get home from work ill take one. They are not yellow.
  20. #20 Re: cam help
    Most likely then they are 105#
cam
