Thread: what AFR?
Results 1 to 20 of 28
  1. #1 what AFR?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Hey I was just wondering what kind of AFR are you all running on your GTP?
  2. #2 Re: what AFR?
  3. #3 Re: what AFR?
    Iz too rich since i'm intercooled.
  4. #4 Re: what AFR?
    Waukesha, WI
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: what AFR?
    Florida
  6. #6 Re: what AFR?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    12.5. I'm gonna add some fuel, add some timing and drop a few pulley sizes when I get a chance to not be lazy and go tune it. Maybe aim for around 11.5. We'll see.
  7. #7 Re: what AFR?
    Charles City, IA
    11.5ish is where you want for a non intercooled car. Intercooled car 12ish.
    SMGPFC Two Nipple General
  8. #8 Re: what AFR?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    11.9-12.2 is usually where im at
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: what AFR?
    Mexico
    I was running 11.2 until today and lower 10's before that. I changed it to 11.5 today. What happens if you run too rich like I did? I only noticed it bogged me down at the end of the track.
  10. #10 Re: what AFR?
    Hagerstown,Md
    If you get to rich that can actually cause knock. You run the risk of White washing the cylinder walls(really rich)m and diminished performance(boging like you experienced). If your gauging your AFR off of Commanded AFR that is NOT accurate one bit. You need to be looking at a wideband
  11. #11 Re: what AFR?
    GTP Level Member
    Pittsburgh
    11.5 with 16-17* of timing, IC'd
    2003 SSEi,
  12. #12 Re: what AFR?
    wait, youre asking this for commanded AFR? UGH.
    get a wideband already.
  13. #13 Re: what AFR?
    12.6 with 20* and a 3.0 pulley ICed...
  14. #14 Re: what AFR?
    Mexico
    I didn't say that.
  15. #15 Re: what AFR?
    Quote Originally Posted by gtpsleeper View Post
    Sex.
  16. #16 Re: what AFR?
    Hagerstown,Md
    Leaners meaner, but id fatten that up to around 12.2 to be safe
  17. #17 Re: what AFR?
    Quote Originally Posted by 01gpgt01 View Post
    was at 12.8 and backed it down to 12.6 to be safe
  18. #18 Re: what AFR?
    Mexico
    So for the wideband, can I only buy the sensor without the dial and plug it directly to the tuner?
  19. #19 Re: what AFR?
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Juanmiguel View Post
    You mean without the guage? You can't just buy the sensor itself, needs a controller or power.
    I'd rather have a wideband with a guage for a couple reasons:
    1. To get the correct AFR setup for scanning, with the guage there you can double check to make sure the formula you entered for PID is correct, sometimes the formula may need adjusting and you don't realize your actually at a 11.2 AFR when the scan says your at a 11.9 AFR...
    2. When you're not scanning it is a great tool to be looking at or to have. You could save an engine or find an issue before it starts to get worse.
  20. #20 Re: what AFR?
    Donating Users crock's Avatar
    Traverse City, Michigan
    wanna get technical, for the normal car 14.7 to one is the best lol
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
afr
