Thread: Could my coupler need change??
Results 1 to 19 of 19
  1. #1 Could my coupler need change??
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Well i know all about the stock supecharger couplers going bad and i ordered a zzp one one month ago. I planned on changing it when i get my car back anyways. So i get it back today and everything is running great except a rattling noise from the supercharger. I just want to make sure that it is the couple that i need to replace and get other opinions. Below is a video of the noise.
    l67 PROJECT :: IMG_1034.mp4 video by GOTIT4CHEAP16 - Photobucket
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Could my coupler need change??
    Jul 2008
    sumter,south carolina
    yessir... change it.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Could my coupler need change??
    Bowie, MD
    Thank you so much gtpinsc good sir. I appreciate it.
  4. #4 Re: Could my coupler need change??
    Jul 2008
    no prob.... u gettin ready to take the motor out?
  5. #5 Re: Could my coupler need change??
    Bowie, MD
    No the motor was removed to add the new tranny in.
  6. #6 Re: Could my coupler need change??
    Jul 2008
    oh ok.... u should prob take the chain off now lol why did motor come out to replace tranny? all it needed was to be supported and take trans out from the bottom.
  7. #7 Re: Could my coupler need change??
    Bowie, MD
    Actually im not quite sure how the shop installed the new tranny but the old tranny that was in the car from the first shop i took it to was the wrong tranny and they never reinstalled the tranny bracket so the whole engine was leaning to the right and uneven. I guess that's what the chain is still there. When i went to the shop earlier to pick up the car it was still attached lol.
  8. #8 Re: Could my coupler need change??
    Jul 2008
    wowwwwwww the shop left a chain hooked to ur motor and u drove it home like that?
  9. #9 Re: Could my coupler need change??
    Bowie, MD
    No i didnt drive it home yet. I left it still at the shop so they can run some more tests tommorow morning before i go back to pick it up. I also want them to replace my power steering fluid leak that i had since my old n/a motor so they are going to check and replace the leaky part tommorow. I will take the chain off tomorrow once i go back to pick up the car.
  10. #10 Re: Could my coupler need change??
    prolly the coupler but is there any noise near the centre of the case?
    If so, thats probably your needle bearings.
  11. #11 Re: Could my coupler need change??
    Bowie, MD
    No the noise is coming mainly from the snout and i finally got the car home today and got ready to change the couple and oil and i saw some play on the supercharger pully when i moved it back and fourth.
    Oh and as i went to remove the supercharger snout fill plug, i seemed to have stripped it and now i dont know what to do. Do i take it to the dealer for them to help remove it or a regular shop?
  12. #12 Re: Could my coupler need change??
    there are extracter tools you can buy or pay someone to get it out.
    Then you need to buy a new one.
    zzp sells them. I'd get a replacement before you attempted to remove the old one.
  13. #13 Re: Could my coupler need change??
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Its not very hard to do. I think it sounds harder than it is to rebuild them.
    My EX wifes other car is a broom.
  14. #14 Re: Could my coupler need change??
    Charles City, IA
    Just take the next size up Allen socket and pound it in the plug and it will take it out.
    SMGPFC Two Nipple General
  15. #15 Re: Could my coupler need change??
    Bowie, MD
    Thanks guys. I ended up buying an extractor and it got it out. Now im going to order a new one from zzp tomorrow.
  16. #16 Re: Could my coupler need change??
    Michigan
    that is the same sound that my charger is making and the oil plug is all rusted, looks like ill be ordering a new plug and coupler myself. This is currently the only vehicle that my wife and I own...it will become a project car eventually but for a little bit here it needs to be a reliable vehicle. Is it going to destroy anything more in the charger if i leave it like that for a little while? Also is there any way to just take the charger off the engine and just run it as a standard 3800? Im guessing ill need to get a new/ different throttle body along with a number of other items that will take just as long to put on then to just change the coupler. Will the new coupler fix the play in the pulley as well?
  17. #17 Re: Could my coupler need change??
    pennsylvania
    i need new coupler also so it takes 6oz of supercharger oil, and i need that gasket stuff is that for putting the snout back on? and coupler just pulls right off right i watched a video on it but didnt really explain much
  18. #18 Re: Could my coupler need change??
    Quote Originally Posted by jspangler22 View Post
    yep take snout off, then the coupler comes right off and put the new one on and it take about 7-8 fl oz of oil. And you need some anerobic sealer for the snout to case, to seal it perfect.
  19. #19 Re: Could my coupler need change??
    pennsylvania
    ok sounds goo thanks my neighbor is like sounds like your engine is about to take a **** because of the horrible rattle noise it makes.
  1. S/C Coupler not right??
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 07-25-2012, 11:45 PM
  2. SC Coupler
    By JB381 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2010, 07:15 PM
  3. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  4. Which coupler?
    By karkrazy1971 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 02:40 PM
