Thread: Front gasket?
Results 1 to 13 of 13
  1. #1 Front gasket?
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey guys. I just pulled my motor because of an extreme oil leak. I am going to replace the oil pan gasket, front gasket and the crank seal. But I needed some help. Does anyone have info on that. And also what else should I change to stop an oil leak?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: Front gasket?
    Omaha, NE
    It depends on where the leak is coming from...
  3. #3 Re: Front gasket?
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    ive replaced the oil pan gasket with the engine in the car and than with it out of the car and lemme just say its million times easier pullin the engine and replacing the gaskets depending on how many miles is on the motor id just do an overhaul while your at it
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  4. #4 Re: Front gasket?
    ooops forgot to read the first part anyways i got the chilton or haynes repair manual and just followed it on there for the oil pan gasket but the head gasket and the crank gastket i had the machine shop do because i didnt wanna fukc anything up.
    SMGPFC #77
  5. #5 Re: Front gasket?
    Orland Park, IL
    The oil leak is coming from the passenger side of the motor. I had a studdering problem due to plug gap, and after I fixed it I stared to give it more gas becase I missed it lol. And 2 days later the oil leak was horrible. The next night I pulled into my garage and left a solid line of oil behind. So you had the front gasket and crank seal replaced at a machine shop... how much did that run you?
  6. #6 Re: Front gasket?
    St. Louis
    Check the oil pressure sensor. It connects near the oil filter and is part of the housing. These have been known to leak right at the electrical connection and cause quite a mess with the oil.
  7. #7 Re: Front gasket?
    i had a complete rebuild with performance stuff also installed so the total cost of my rebuild was like 1100 and had them do the short and long block assembly but then again everywhere else is different but if its the front im sure it should be easy especially if u already have the motor out. best thing u can do is look at the repair manual or ask the dealership how to replace it not saying have them do it cuz itll prob cost u an arm and a leg but ask them how.
    SMGPFC #77
  8. #8 Re: Front gasket?
    Orland Park, IL
    And I also forgot to mention that oil gets on the belt so it sprays oil on the firewall snout and hood.
  9. #9 Re: Front gasket?
    You don't have anything over there that should be able to do anything more than seep, except for the oil pressure sensor.
    Clean it down, then run it and look for the leak. Clearly it's leaking enough to visually see it. Find the leak, fix the leak...
    Don't pull a motor just to do it. Honestly..it's not that much fun.
  10. #10 Re: Front gasket?
    Orland Park, IL
    Well the problem is that I already pulled it because I thought it was the front gasket and I just wanted to know a little more about it. But thanks guys.
  11. #11 Re: Front gasket?
    wow talk about jumping in with both feet.
  12. #12 Re: Front gasket?
    St. Louis
    Well hell, at that point I'd go through all of the motor and replace any/all parts that I can. Probably would replace the rack too if its leaking.
    Man, that's a lot of work/time for something that could be simple. I just hope that once you get it all back in you still don't have a leak
  13. #13 Re: Front gasket?
    port the s/c while u have the engine out while your at it
    SMGPFC #77
  1. Oil pan gasket
    By Jochen in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2012, 10:23 PM
  2. LIM gasket
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-11-2011, 03:45 PM
  3. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  4. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
