Re: What pulley should I run?
bluegtp91
I understand...I'm just saying that to get potential out of the setup I wouldn't go little part by part...I'd wait and throw it all on at once.
Agreed. My plans are a 2-step process based on money & time. Step 1: 3.4" gen 3 setup. Step 2: throw on I/C, LIM, GenV, N* & rockers. I'm gonna try to score the N* & gen V from a junkyard, which will take some time, so I want to hold myself over with Step 1 for the time being.
bluegtp91
The tune takes care of the fan turn on points for the 180* T-Stat to when the motor gets to 180* the fans kick on vs. the stock points...that is all that does...
Maybe I'll wait to drop pulleys till I intercool. I hate the idea of constantly running the engine at 180*... I feel like I'd be killing it (as if modding wasn't gonna do that first). Not to mention the crappy MPG's. However, I suppose I could switch back to the 195* after I intercool.
bluegtp91
^^I knew I typed that sometime lol....
Thanks. I remember reading that.
One more: how essential is the ported TB/SC for running knock-free at the 3.4" level? I should mention I use 93 octane. Trying to avoid the hassle when I'm gonna toss the gen 3 & tb eventually.
Not really...porting the blower lowers outlet temps and since there is less heat it kills KR a little more...some people claim to have noticed a good amount of KR drop, others not so much. My theory is that the people that noticed it more had an over ported blower...but thats just me.
93 is great...and honestly, you really don't need a Ported TB or S/C...its just a nice bonus. Also, if you port your throttle body you WILL need a retune on the MAF tables...since the ported TB will change them. A canned tune will not suffice.
Will I also need a custom tune for the N*, or do Overkill, etc. use the standard MAF tables for LQ4 + N* that I see on ZZP's website?
And basically, we're stuck with a 2-3MPG hit when we go to the 180*.
If your car is going to be modded enough for an aftermarket MAF you'll want an in car tune.
So, to sum it up, I think I'll drop to the 3.4 after getting my 180* & canned tune in there. So it will be headers, intake, 180, 104s, overkilled. Obviously I'll be scanning.
From there I'll work on getting my genV. When I make my next drop, I'll be at gen V, full IC, 1.9RR, N*, LQ4. At that point I'll go for the in-car tune. Which reminds me, will I need a wideband for the tuner?
Sound good? Thoughts on pulley size for my second setup?
Never tune on the narrowband (factory o2 readings)...at that mod level you might consider learning how to tune and getting it done yourself that way you can tune on the fly due to weather changes and it isn't just a balls out tune you'd get for a 60* day...because when its 30* out...hello knock...and you'd have no way to fix it besides either not getting in the throttle or pulley'n up.
Second setup...I say 3.2". Why not smaller on a full-size IC/rockers/headers? Because I'd run that 3.2", on pump 93...and crank the timing on stock injectors and hope your IPW's don't run static.
nick, stop telling people to run 180* thermostats.
Ok.
Run a drilled 160* like I do.
It's chewing tabacco...what do you do with it?
Chew it of course.
Also, rules don't apply to blue cars since they destroy all common knowledge and procedures and throw them out the back door.
I'll put new injectors on, no problem. I planned to, just forgot to mention them.
Bio, what's your opinion on the t-stat... I'm interested to hear as I'd like to avoid the 180 if at all possible - for mileage and the health of the engine.
Also, I really really would like to learn to tune on my own. I guess I just need to read up on what the best way to do that is...
running colder only decreases mileage because the engine isn't running at true operating temperature and it increases engine wear.
it is an old school trick they used back in the day when they had no tuners. the only thing they could do to combat detonation was run the motor colder, scale their MAFs to add fuel, and run race gas. now with tuners all over the place there is no reason to even do it. i would personally just run a stock thermostat and never care.
What pulley do you think I could run on the 3.4 setup sans 180? I'm willing to sacrifice some performance to stay with the 195 and combat knock in better ways.
You think I should add a wideband now and tune myself for the 3.4 setup? Otherwise, isn't Reptile in NW Indiana (I'm in SW MI)?
T0pwater
Missouri.
And a wideband is always worth it. Narrowband sucks.
Anybody running a stock t-stat w/ a 3.4 or 3.5 pulley?
T0pwater
Probably not...and honestly...as long as the fan turn-on points are set correctly...you aren't going to really notice the difference in a cooler T-Stat. Also, the MPG's you MIGHT lose from tossing in a cooler T-Stat, your going to gain back (plus more)with headers/intake/tune
bluegtp91
I think the one way to know is to try it... I'll get a 3.5 for now and once I find a tuner near me, I'll put it on. But I'm pretty dead-set on keeping the 195 stat.... sorry, but I just feel like it matters, not only MPG's but longevity too.
As far as fan turn-on points, I'm not really into the strip and I don't live in the city, so it's not as huge for me as it is for some. If I can street my car and wax enough people there I'll be more than happy. But just in case I'll make sure when I tune to get the turn-on points lowered. Where should I set them for a 195 stat... 195?
I THINK, factory settings are 210* or around there.
But...it wouldn't hurt to turn it down a bit just to keep things cool. One thing I do like about the tunes is also the fan settings after you turn off your car they will keep running for a couple minutes
When I first saw the title of this thread I thought, oh no here goes another one. I've been following it and its really turned out to be a cool thread.:th_thumbsup-wink:
I decided to keep my t-stat at 195 when I did my lim as I have also heard about the slight wear issue with cooler running temps. With a high mileage(180k) near-stock engine like mine, I think 195 is the way to go.
