the car has the following
xp cam
42# injectors
full size intercooler
LQ4
and stock 150k fuel pump, no re-wire
im trying to figure out whats going on, i got my car on the road today, idled great, bled the coolant, then went driving around. When i was rolling into the throttle in 2nd gear i noticed my wideband went straight to 17 in the red, i stayed on it for a couple of seconds, it was still pegged. Even normal driving if i hit a hill or something and the car is at a low rpm in 2nd my wideband pegs lean. I stopped the car, turned it off, added some fuel with my tuner, go to start it and nothing, cranks, idles for a sec then dies. I put fuel back to the way it was and the same thing happend, then i hear the pump either, not whinning or whinning funny, not sounding the way it should. I swapped the fuel pump relay from my other car, started it, ran rough, still leaning out in areas where its not supposed to, and actually feeling it bog. I managed to make it home.
im guessing i need a high flow fuel pump and re-wire? I was eying up prj's kit. what are u guys using for fuel with similar setups?
