Thread: hard start issue... PLEASE HELP!!!
Results 1 to 4 of 4
  1. #1 hard start issue... PLEASE HELP!!!
    Warren, MI
    ok so here are the symptoms
    > weather the engine is cold or hot, or the weather is cold or hot, it makes no difference... when i start the car, it cranks and cranks for about 5 to 10 seconds then turns over. right away i have to put my foot on the gas (only for a second) to keep it running or it will stall instantly. after giving it a second on the gas it runs perfectly. no fluctualtin idle or anything. i dont even notice any loss of performance.
    > it did stall on me ONCE. after i just got off the freeway for about a 5 minute 75 mph ride. it started up the same way it has been. cranks for a few seconds then turns over.
    >the only code its throwing is P0420. something to do with emission threshold too high bank 1 i think, or something like that.
    > bought the car with 133xxx miles. now has almost 135xxx. although the odometer has those white lines between the digits which i know means it was altered. could mean a replacement cluster, could mean the guy screwed me. the only way to narrow down the real milage is carfax which im broke so... lol
    > i recently replaced the fuel pump with a cheap chinese ebay oem POS. also a cheap chinese made ebay MAF. the MAF threw a code and it has since disappeared after i replaced it.
    > i have collected from this forum a few posibilities... bad fuel pump, fuel filter, FPR, IAC, PCV, MAF, this sensor, that sensor, the other sensor, a combination of 652 different sensors (lmao). just wanna know how to test for all the posibilities cause i dont wanna just jump in and start replacing stuff and by time im done, have replace avery sensor, valve, relay, and regulator on the entire car.
    > your help is much appreciated
    Thanks!!!
  2. #2 Re: hard start issue... PLEASE HELP!!!
    Apr 2011
    Houston,TX
    Check your fuel pressure during those 5-10 seconds of cranking.
  3. #3 Re: hard start issue... PLEASE HELP!!!
    A bad cat code may be telling you that the cat is plugged. Have it checked for backpressure.
  4. #4 Re: hard start issue... PLEASE HELP!!!
    Warren, MI
    Ok... I know there's a special tool for checking fuel line pressure but where do I hook it up at? I can prolly rent the tool from autozone or somewhere like that.
    Would the bad cat code cause my starting issue? It is original cat.
    Thanks!
  1. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  2. Hard Start When Cold
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 04-28-2011, 10:36 PM
  3. unpredictable hard start.
    By Teardrop in forum General Tech Discussion
    Last Post: 11-08-2010, 02:47 PM
  4. Car hard to start.
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 11:44 AM
  5. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
